Results 1 to 10 of 14
Thread: Halfords Professional 10 Piece Flex-head Ratchet Spanner Set - worth buying?
    [Ex]Admin Duncan's Avatar
    Default Halfords Professional 10 Piece Flex-head Ratchet Spanner Set - worth buying?
    As above, it's currently half-price.
    The bit that interested me was the flexible head bit. I've already got some ratchet spanners in the Halfords Pro 150 piece kit I have i.e. 8/10mm, 12/13mm and 17/19mm so the only sizes I'd gain as ratchets would be the 14/15mm - so the flexi-head is the real main difference. I've even got the adapters that let you use sockets in my ratchet spanners.
    Sooo, I have two questions...
    1) Has anyone got these?
    2) How often have you found the flexi-head part useful when doing jobs? Often enough to take a punt at £40 for them?, or rarely and I'm just as better off sticking with the ratchet spanners I have? - albeit without the 14/15mm sizes that are in that kit that I don't have. Although I can't recall when I've wanted/needed that size as a ratchet TBH.
    Any feedback welcome.
    Ta
    Ta
    Blimy I'm glad I didn't go to halfords today, could have broke the bank or given the card a good bashing, all these lovely thing for sale. ..
    Regular Member Jason123's Avatar
    Ive borrowed friends before, never found the swivel head able to get anywhere a socket and extension bar couldnt.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    How can you get any Umph on the spanner if its at a 90 angle?
    Quote Originally Posted by Jason123 View Post
    I was in Halfords a short while ago looking at some other stuff and had a look at this set. On the main 'shaft' just before it meets the hinged bit it flairs out a bit, so reasonably chunky, and I wonder if it'd actually be harder to get into some bits compared to, as you say, an extension bar (on it's wobbly setting if needed).
    Quote Originally Posted by andymagee1982 View Post
    That was also a thought I had - although I 'spose in most actual cases you wouldn't be at 90 degrees, probably somewhere in between.
    Well I think until I get a chance to try one 'in anger' I'm not going to punt £40 just to find that I don't use them/don't like them - especially as I've never thought to date "Oh, I wish I had a a flex-head spanner for that job!" lol
    Thanks for the input BTW guys.
    Full Member Big Sig's Avatar
    I have a set and use them at work - engineer in a large factory. They are very good and the flex is a useful feature. When using them at 90 degrees just put an adjustable on the top and off you go! They are 100 times better then the fixed ones imo as they have no offset like a normal ring spanner. I have never broken one and they do get some abuse.
    I did recently discover that the "lifetime warranty" does not cover any moving parts on any of the professional range.
    http://www.halfords.com/webapp/wcs/s...Id_165572#dtab
    "How does the life time guarantee work ?
    Q: I own a set of flex head rachet spanners from the halfords professional range. Some of the rachet heads have started to slip making them useless. The problem is i am not sure i have the reciept from when i purchased the set. How do i go about getting the broken ones repaired or replaced ?
    8 months ago
    by Anonymous - St Neots, Cambridgeshire
    Answers
    Number One Contributor
    A: The metals of the tools in the Halfords Professional Rachet Spanner Set are guaranteed. The moving parts (rachets) are not covered under this warranty.
    A proof of purchase is likely to be required by stores for replacement of spanners in the set which have suffered metal corrosion.
    8 months ago
    by HalfordsWebTeam"
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    8 months ago
    Answers
    8 months ago
    by HalfordsWebTeam"
    well my local halfords have replaced 3 ratches,4 spanners,5 sockets,4 torx bits and all 3 ratches spaners out of my 150 ps kit with no problems ( never asked me to see recipte either)
    You're meaning the angle that a ring spanner has? If so then yes, the straighter ratchet spanner can be a boon there - as can can the angled ring spanner as well! lol
    Also, how would you rate the against a normal double-ended ratchet spanner? That's what I have three of (i.e. 6 sizes) hence me wondering if I'd be gaining much. Is the flexi-head worth getting even if I have a few ratchet spanners already?
    Yeah, I noticed that too - only to be expected I 'spose. I know you can get a racthet repair (replacement) kit for the ratchet handles - not sure if you get the same for the ratchet spanners?
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have some of these too and find them very good. I used them at the weekend to undo the Exhaust clamp on a Veccy SRI Backbox as the bolt is too long even for long reach sockets and it took some severe pressure on it and it worked a treat and the way you can change the angle is really handy. I have had mine for a couple of years now and they are still as shiny now as when they were new
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    this site is SERIOUSLY bad for your wallet...they do look good.
  1. Halfords 150 Piece Socket/Ratchet Set
    By hadiislam in forum General Chat
    Last Post: 19th March 2012, 14:28
  2. Replies: 10
    Last Post: 19th April 2009, 22:56
  3. Replies: 1
    Last Post: 19th April 2009, 19:50
  4. Halfords Professional 150 piece Socket/Ratchet Set
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 18:05
  5. Halfords Professional 150 piece socket/ratchet set
    By Duncan in forum General Chat
    Last Post: 22nd January 2006, 23:58
