Thread: fitting sub/amp with standard stereo
    brum
    Default fitting sub/amp with standard stereo
    Hi there i have fitted my sub and amp package to my vectra but im unsure what to come off for the remote wire?
    i have done the earth and the constant live. i have used one of those speake wire convertors for the rca leads on the back of the stereo so should all this work when i have attached the remote to something?
    thanx beno
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The easiest place is the ciggy lighter,it's a proper ignition live, not involved with anything canbus.
    Northampton
    oh nice, i was looking to do this with my standard unit, i have the rca convertor but its been sitting gatherin dust. i dont know how to fit it! can you take any pics while your doing it mate?
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    i would also like to know how this is done as cant realy afford the get the head unit i want at the mo so pics/ how to please
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I have a nice sub and amp for sale,12" infinity sub + mutant amp (200w,RMS),here the sub,http://www.incarexpress.co.uk/view_p...no=REF1200B.70 quid for the pair.The amp has high level inputs,no need for a rca converter.
    brum
    ok nice one ill try that tonight. i have just attached the speaker wires to the stereo loom speaker wires behind the H/U
    brum
    hiya my multimeter is dead so i dont know which wire to use, any one know?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Quote Originally Posted by bigben View Post
    You can also pick them up from the rear door loom in the n/s trunking.
    There's a 2 wire plug on the socket,ones earth and ones the live,you can use a spare h/lamp bulb as a test light,try it on each wire to a separate earth,just be careful where you rest the bulb as it gets hot!
  1. changing standard stereo?
    By dickos in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2010, 12:42
  2. Standard Stereo replacement
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2010, 10:48
  3. Does your standard stereo.....
    By cpt slow in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2009, 15:16
  4. standard stereo
    By swalk999 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2007, 16:22
https:www.vectra-c.comforumshowthread.php73264-fitting-sub-amp-with-standard-stereo
Does a vectra have sub
fitting sub to standard insignia stereo
fitting a subwoofer to standard vauxhall vectra stereo
fit a sub to vectra c sat nav sterel
fitting a sub to a vauxhall insignia
speaker wiring for vauxhall signum
vectra c head unit sub install
can I fit up date car radio in vectra c
vectra c is it better to replace stereo or buy an amp
2007 vauxhall vectra c amplifier
can you run a sub and amp from the 2006 radio vectra c
fitting sub and amp vectra c
sub input vauxhall.standard stereo
