Results 1 to 10 of 14
Thread: Exhaust and Skirt Progress
    Admin plasma's Avatar
    On the Forum
    220 Post(s)
    Engine : 150
    Mileage : 74000
    Default Exhaust and Skirt Progress
    The rear skirt is on and so are the exhausts. But the exhausts need moving into proper position so equal gaps are around all sides. If u look at the right hand exhaust does it seem that one of the 2 tail pipes looks pi**ed a bit as if it wasnt welded on straight.??
    The right hand is defo off a bit, maybe not welded but just at an angle, the left hand side doesn`t look bang on either, are they supposed to be the same height ? and did vx do it for you ?
    On the Forum
    220 Post(s)
    Engine : 150
    Mileage : 74000
    Vx didnt do it for me, got some guy to fit the exhaust but didnt have the rear skirt on so he couldnt line it up. Need to get it put in now to have everything lined up.
    Will look the mutts when it is finished and sprayed thats for sure ...
    Mileage : 000
    Hey they look brilliant, will look even better when painted. may be put a pice of wood the same size as the bore and try and twist the wood,it might pull the offending exhaust in line?.
    The left hand side looks spot on to me (they're not supposed to be in line), but the right hand defo needs looking at and lifting slightly.
    If they aren`t supposed to be the same height the right hand side probably just needs twisted slightly anticlockwise ...
    On the Forum
    220 Post(s)
    Engine : 150
    Mileage : 74000
    Right hand one was a ***** to try to adjust this morning, only had a ring spanner, need some proper sockets. Couldnt find mine for luv nor money. If you blow the pic up full screen u can see one of the outlets is twisted. doesnt look like its right even though height of box not right yet.
    Jan 2006
    Dalriada
    will look great when its done mate
    If they are not quite right I would get another from irmscher as they aren`t cheap so should be spot on ...
  1. Rear skirt and exhaust insert
    By BigWilko in forum Bodywork & Interior
    Last Post: 11th March 2012, 21:31
  2. Signum Exhaust & Skirt For Sale
    By themarbleman in forum Parts for sale
    Last Post: 16th April 2011, 18:15
  3. Progress on Rear skirt
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2006, 23:39
