Results 1 to 10 of 14
Thread: When fitting new springs...
    Northampton, UK
    Default When fitting new springs...
    ...Do you need to add anything else? Is there anything thats recommended to add if its not fitted as standard?
    I remember reading somthing about "Spring Assistants"(?) and spring "Socks"(?)... No idea where I got this from...
    I'm lowering my Signum by 25mm and 35mm, can't remeber which way round at the moment .
    Its the Preface Design model, so its lowered by 15mm as standard I believe, so only going a little lower...
    Any suggestions or comments? Thanks people
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Contact your local stealer and get the spring modification slooeves/sock's... just a few quid im sure..
    Regular Member cookiejar31's Avatar
    Jan 2008
    leicester
    wot do these sleves do as im getting my car lowered on saturday with new shocks will i need the sleves?
    Was a modification vauxhall came up with to prevent spring brakages... i dont know alot about it but it seems to get advised to do this ...someone with more know how will be along soon i would imagine
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I thought it was to stop the springs making a grinding noise when turning the steering. The sleeves go on the bottom of the front springs
    I thought this was related to the springs braking? lol
    Northampton, UK
    Only the fronts get the sleeves? So there's no such thing as Spring Assistant thingy-me-jigs? LOL
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Only if your gonna be towing or carrying heavy loads and it drops to much at the back. If not then you won't need them
    And yeah only the fronts
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Neil what about camber adjustment bolts , recommended if a car is lowered more than 25mm.
    Eibach do them cost around £20 from lmf
    and still loving it
    Northampton, UK
    Quote Originally Posted by bobssignum View Post
    Camber bolts???
  1. fitting new springs
    By redross555 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2011, 21:21
  2. fitting new springs
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 15:17
  3. My Car after fitting springs!!
    By Sean-2.2Direct in forum Quick Photo Album
    Last Post: 22nd October 2009, 22:00
  4. Fitting springs
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 19:10
vectra c springs which way round fitted
