Thread: Leak off pipes 2.0DTI - Guide?
    Swansea
    Default Leak off pipes 2.0DTI - Guide?
    Hi Guys
    I think i've got a problem with my leak off pipes from what I've found searching on these forums.
    Had cold start issues and couldnt find reference in the service stuffs to the glowplugs having been changed so those have been done and not improved matters so it seems my next port of call is the leak off pipes.
    I've found this thread with some pics
    http://www.vectra-c.com/forum/showthread.php?t=59573
    But i was wondering if anyone had a Derv newb friendly guide or advice before I tackle it.
    Also, does anyone know what pipe (and size) is suitable for this task?
    Thanks in advance
    mark
    Full Member
    Bristol
    Mark Hi the only bit of advice is buy vauxhall genuine leakoff pipe and new T pieces. Replace t pieces even if they look good. Remove all the leakoff pipes and measure and cut the new pipe to match. When putting together put a little fairy liquid on each joint even when you put them on the injectors leakoff conectors , as the pipe will be hard to push on t pieces etc.
    When you start car it may take a time so don't just site there turning it over give it a breather or you will burn your starter out.
    Swansea
    Ok. Was hoping to avoid Vauxhall but hey ho
    Any ideas of the cost before I ring them on monday?
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by Spesh View Post
    At a gues from there £10-£15 for the lot?
    Take the advise on the re' starting isue as the starter will burn out from experience.
    Hope it works for you mate.
    Swansea
    cool thanks
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    cool thanks
    Hello Spesh - just been reading this thread as my 2.2DTi failed to start today, and wondered it this worked for you or not?
    Si
    Swansea
    Still not done it Si, i'm rather lazy
    Admin plasma's Avatar
    On the Forum
    327 Post(s)
    Engine : 150
    Mileage : 74000
    Dont leave it too long is my advice, all the time its not starting the pump isnt being lubricated by the diesel and leads to premature failure of the pump
  1. 2.0dti intercooler pipes collapses!
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 18:22
  2. Leak off pipes
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 8th April 2010, 22:06
  3. Big black pipes on 2.0dti
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 11:22
  4. Leak Off Pipes???
    By st2malo in forum Engine & Drivetrain
    Last Post: 17th March 2010, 01:08
  5. leak off pipes
    By Mort in forum Engine & Drivetrain
    Last Post: 7th June 2008, 11:54
