Thread: VDA Connector Confirmation
    Sofia
    confused VDA Connector Confirmation
    Hi Folks,
    Can someone please confirm is this a VDA Plug (in red circle). This is not exactly my connector but mine looks the same.
    I have preinstalled microphone and just got a new Opel UHP module so I want to connect the UHP to the VDA. I have CD70 with a color display. Is there a universal cable between the UHP and the VDA (online magazine or part number)?
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    no no, the VDA-plug looks like this:
    you can find it -if you are lucky- behind the handglove compartiment, on the left, taped to the side
    what you can see in your picture is the location of the aerial if it was not where you expected it to find (together with the VDA): see the yellow arrow, it is one of the black coax-cables in the string
    Sofia
    Thanks a lot sig63
    I found it at last. Now the problem is to connect the VDA to the Opel UHP module. Someone have an idea?
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    You need the UHP-plug-repair-set ("UHP-Stecker-Reparatur-Satz"); as far as I know, it does not have a part number - but andy.l can correct me - price around 50 euro
    Sofia
    Quote Originally Posted by sig63 View Post
    You mean Opel produce this “UHP-plug-repair-set” so I can check with some local dealers?
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    yes
    Sofia
    Big problem appears here I’ve checked today all Opel dealers here in Bulgaria and no one can help me, all says Opel don’t have such cable. Can someone direct me with Opel/Vauxhall part number or something else?
    Sofia
    Help please part number site anything ?
    Sofia
    Hum I just realize this connection will not going to happen. The problem is that the VDA plug do not have CAN bus signals, so you cannot control the “Delphi-Grundig” UHP. That’s why for example Parrot BT devices have external button for control. So I must go to retrofit.
    Just for the record here's the pin out on the VDA plugs:
    EARTH - PIN 1
    PERMANENT 12v - PIN 11
    IGNITION 12v - PIN 10
    RADIO MUTE - PIN 4
    AUDIO IN +ve - PIN 16
    AUDIO IN -ve - PIN 7
    MIC +ve - PIN 18
    MIC -ve - PIN 9
  1. Confirmation please
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2009, 21:41
vectra c kein vda bei uhp
pin outs of vda
opel vectra c quick connector
