Thread: 2.2 direct rattle
    Regular Member sidturbo's Avatar
    burnley
    Default 2.2 direct rattle
    hi all, just noticed a very tinny rattle when my revs drop on the pully side of the engine, anybody heard of this before? also bit of a grunting noise from under bonnet when i first let the clutch out!!!
    Regular Member mspvxr's Avatar
    May 2007
    Chugging along
    Vehicle : Vxr in red
    I had this on mine. Vx couldnt find the fault so i sold it.
    Same motor this way no problems ... :ranger;
    Regular Member Resolute Blue's Avatar
    Cheltenham
    Quote Originally Posted by sidturbo View Post
    Not sure if it is related but I had a similar problem on my 2.2 direct with 32,000 miles on the clock. I ended up changing the timing and balance chains plus the associated tensioners and pulleys etc which cured the problem.
    You can't push over 150bhp through what is nothing more than a bike chain and expect harmony under the bonnet!
    Good luck!
    Quote Originally Posted by Resolute Blue View Post
    Well the 2.0T is 175bhp and also chain driven.
    burnley
    it only seems to do it when the engine is warm!. The car is covered by a network q warranty so hopefully it will be covered, anybody know how good the network q warranty is?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The engines good for 700BHP with off the shelf GM parts. Supercharging them is getting quite common now. GM use uprated parts now in the 2.2, think they are from the 2.0T, and as far as i'm aware no 2.0T have ever had a chain problem?
    burnley
    dealers discovered it was the timing chain that was goosed, all fixed by them as it was a network q car bought from them luckily had a month left on netq warranty so all done for sod all, who says the 2.2 direct timing chain doesnt fail? only done 38k aswell!!!
    Pleased to hear you're sorted & at no cost to the pocket. .. ......
  1. Replies: 35
    Last Post: 5th May 2012, 15:32
  2. 2.2 non direct rattle
    By Ben_ in forum Engine & Drivetrain
    Last Post: 15th April 2012, 22:31
  3. 2.2 direct.timing chain rattle.
    By Dobs in forum Engine & Drivetrain
    Last Post: 4th April 2012, 20:47
  4. Newbie Advice needed please 2.2 Direct with a strange rattle...
    By simp_2.2sri in forum Introduce yourself.
    Last Post: 10th August 2008, 17:24
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
