Results 1 to 2 of 2
Thread: what should I do........?
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default what should I do........?
    I own a 2.2dti c with 108k on the clock, its running well so no plans to get rid but I want it to go and run as good as it could.
    so what do I need to do, to keep it sweet?
    I've done so far:
    oil and filter change 8k ago
    cleaned the egr valve 2 week ago
    replaced the air filter 2 weeks ago
    replaced the pollen filter 2 weeks ago
    replaced the rear disks and pads last week
    replaced the NSR hub about a 1000 miles ago
    can anyone think of anything I should look at, I want the handling to be as sharp as it once was.
    many thanks if you can help.
    Kent
    there is a boost sensor which gets covered in gunge you could clean or replace that, maybe the leak off pipes?
