Thread: P0381 Glow Device Circuit Low Voltage
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Default P0381 Glow Device Circuit Low Voltage
    Fault P0381 Glow Device Circuit Low Voltage. Would this just be the glow plugs that need replacing ? thanks
    preston
    Just changed the glow plugs on mine and I'm pretty sure I got the same error message. Glow plugs are £8 each
    Feb 2006
    west midlands
    Quote Originally Posted by bygumlad View Post
    Do you get the car with the spanner light come on when starting below 5c ?
    Well i did for a while its just getting more & more often now even at 8c.
    Thanks for your reply
    May 2007
    southend on sea
    Had the same symptons on mine, glow plug cured it, careful taking it out though, they are quite long and not that strong.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0381 - Glow Plug/Heater Indicator Circuit Malfunction, could be a plug, or could be the controller. Try each plug for resistance before you remove them by removing the wiring linkage and test each one. You will soon identify a duff one.
    Feb 2006
    west midlands
    Thanks guys.I will get some new glow plugs fingers crossed it will sort my problem out . Not sure how to test the old plugs first ?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I see no point in changing good glow plugs. Not only does it cost you money to replace effectively good parts, but also there is some increased risk of snapping one off and needing more expensive remedial action.
    As the electrical connections have to be disconnected to remove them, there is no more work to do. Simply remove the electrical connectors from each plug and then apply a multi meter across the glow plug connector and the engine block and measure resistance. All 4 glow plugs should show similar values.
    Feb 2006
    west midlands
    Quote Originally Posted by Ste View Post
    Thanks m8
    Feb 2006
    west midlands
    Sorry to sound dim , Do i have the ignition on/off or the engine running ?
    What sort of readings should i be getting ? Thanks
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You are only checking the resistance of each glow plug, so it matters not what the engine is doing (best have it switched off due to moving parts / hot etc.
    I can't remember the value you should get (it on this forum somewhere, so use of the search function may be necessary)
    But it will be very evident if one is way off the rest
  1. Instrument Dimming Bulb Output Circuit Open or High Voltage
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2016, 20:24
  2. glow device general error
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 14th January 2013, 22:59
  3. B3803 - Comfort Closing Low Voltage or Circuit Open ???
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 16:22
  4. P0615-02 Starter relay circuit voltage (fault code any help)
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th September 2011, 15:17
  5. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
p0381 opel astra g
glow device circuit low voltage
astra p0381
p0381 vauxhall
astra g y17dt p0381
Fault code 0381 Astra mk4 tdi
opel signum 3.0 cdti glow plug device low voltage
p0381 nissan quasquai 1.5 dci
low voltage to my glow plugs on my vauxhall vectra
p0381 vauxhall cores
voltage for vectra c
p0381 opel zafira
fault code 0381
P0381 opel agila
OPEL P0381
vauxhall corsa d glow plug low voltage
VAUXHALL P0381
saab glow plug low voltage
heater circuit p0381
voltage to glow plugs on insignia
vectra c glow plug low voltage
