Thread: this anygood???
    Carnoustie
    Default this anygood???
    copied from the description what will these be able to do or not do?
    Brand new OP-COM CAN BUS INTERFACE FOR Opel Vauxhall with software
    OP-COM is a PC based diagnostic program for OPEL CARS, support CAN BUS
    It covers almost all Vauxhall/Opel cars, even new cars with CAN-BUS based diagnostic, such as Vectra-C, Astra-H, Zafira-B.
    The program lets you to read out and clear fault codes, shows you live data, lets you to perform output test, and supports remote, and key programming.
    * The program supports many control units, like Engine, Automatic Transmission, ABS, Airbag, Engine Cooling module, Instrument Cluster, Electronic Climate Control, Body Control Unit, and many more.
    * Opel uses many pin in the OBD connector, the diagnostic interface works as a multiplexer, and selects the appropriate pin for communication.
    * PIN3, PIN7, PIN8, PIN12 = Serial Link (ISO9141, KW81, KW82, KWP2000)
    * Fault codes will be shown with all available information:
    * Full fault code text desc ription
    * Full status information (Present, Not present, Intermittent)
    * It can print out, save, or copy the fault codes to any other application.
    From the fault codes window, you can go directly to the measuring blocks window.
    * The program can show you measuring block information on many control module, you can choose anything from the list on your own. The program is capable of showing 8 measuring block parameter simultaneously. The sample rate is depends mostly on the communication protocol. For example, older system, like Omega-B X 25 DT Engine (ISO-9141-2) can be very slow, during communication, while newer Multec, or Bosch units are faster (using KWP-2000), and the newest CAN based control units are very fast!
    * It can be run output tests on many controllers.
    PIN6-PIN14
    PIN3-PIN11
    PIN1
    HSCAN - Dual-wire, High Speed CAN-BUS, 500 kbps
    MSCAN - Dual-wire, Medium Speed CAN-BUS, 95 kbps
    SWCAN - Single-wire, Low Speed CAN-BUS, 33.3 kbps
    The feedback on the state of the activated can be genetated. It can help you to find the failed components more quickly.
    The diagnostic inteface is USB port based, so there will be NO COMPATIBILITY ISSUES, with serial to USB
    converters.The speed of the communication over the USB-BUS is enough to handle the awesome speed of the High-Speed
    CAN-BUS systems, which is currently 500kbps. This is the main reason, why only the USB port based interface is
    available for CAN-BUS.
    Compared to the TECH2, which is the dealers tool (with a 32 MB card+CANdi interface), the price of OP-COM is quite affordable.
    With OP-COM, you can learn keys to immobiliser, and remote keys to the central door locking, or alarm.
    You can also reset, and program the following immobiliser related items: ECM, BCM, IPC.
    You will need the vehicle security code, which can be found on the CAR-PASS.
    You can also reset, and program the Service interval reminder on Astra-G, Zafira, Corsa-C, Meriva, Tigra-B
    You can code SAB6, and SAB8 airbags with the software.
    any pointers appreciated
    thanks Ronnie
    Regular Member gromit's Avatar
    Cumbernauld
    Think this might get removed as ebay are fine listing it but the admin on vectra-c.com aint.
    Carnoustie
    Quote Originally Posted by gromit View Post
    EH! its not a link to the auction, only part of a description so could be from anywhere
    Being watched carefully!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i was wating for that
    Cumbernauld
    Me too
    Regular Member djr69uk's Avatar
    Midlands
    Light the blue touch paper and run...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I can't see any problem with this on here, as long as it is advertising legit software.
    OP-COM or VAUX-COM will do nearly as much as Tec 2, but can't download software updates etc.
    Good bit of kit, I may be after a replacement interface too.
  1. Are these bearings anygood
    By veclee in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2013, 22:17
  2. These anygood?
    By degsy1234 in forum Styling
    Last Post: 28th June 2011, 15:54
  3. daisy anygood
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 29th September 2009, 01:05
  4. cdti 150 anygood am worried
    By galway1 in forum Engine & Drivetrain
    Last Post: 20th May 2009, 23:24
