Thread: How to reset spanner light?
    Aylesbury
    Default How to reset spanner light?
    Hi guys, hope you can help.
    Just picked up my 2.0DTi signum after having the EGR replaced but the garage did not reset the spanner light after doing the work.
    Will it go out eventually after anumber of starts or do i have to drive another 60 miles back to the garage for them to reset it?
    Or is there a way of resetting it myself?
    thanks in advance.
    Plymouth
    I know there is manual ways to reset similar things on the Skodas VW's etc...
    I did my sis Fabia the other day and that was.
    Put key in car,
    Hold trip reset button in. turn ignition so all the lights on the dash come on...
    Keep button pushed in untill the inspection symbol turned off..
    Try something similar.... it may work...
    But im sure someone will be along very shortly with the exact how 2
    Regular Member LJ sxi-nav's Avatar
    Winchester
    search the forum
    basically the EML (car/spanner) will reset after 40-odd successful restarts with no fault recurring in that time. Or you could disconnect the battery for half-hour or so (do you have the radio code, if needed?)
    Diet1985 - There is a way to reset the SERVICE light (Oilcan/Spanner), very similar to your instructions - it does involve holding trip reset (and sometimes the brake pedal) before turning on ignition and holding both trip reset (and pedal) for a few seconds.
    If it stays on until the engine has started, it's indicating a stored fault code. As said, after a number of key turns or 'x' amount of days it will clear providing no further faults occur.
    If it stays on after the engine is running, then a fault is still present.
  1. Spanner light.how do i reset?
    By Dobs in forum Engine & Drivetrain
    Last Post: 24th August 2012, 02:16
  2. Can the car/spanner light be reset?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 19:25
  3. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  4. Spanner Light - Does it need to be reset?
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 05:56
  5. Spanner light & ECU reset - 2002 GSi
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 8th March 2008, 08:29
astra spanner light reset
vectra c spanner light reset
vauxhall insignia spanner light reset
corsa c spanner light reset
vectra spanner light reset
https:www.vectra-c.comforumshowthread.php72961-How-to-reset-spanner-light
vauxhall zafira spanner light reset
how to knock spanner light off on vauxhall vectra sri 07 modelhow to turn vauxhall corsa c spanner light offhow to turn off car with spanner light opel corsa chow to reset spanner light on corsa cvectra c 1999 spanner light resetOpel corsa spanner light resethow to reset spanner light on zafirahow to reset vectra c service lightremone spanner light vectra batteryhow to reset spanner service light signum 30 cdtihow to reset vectra dtihow do I get rid of the spanner symbol on my vectra chow to reset spanner on opel astra cdtireset service light vectra-cvauxhall zafira 2.0 dti spanner lightvauxhall vectra 19 dti reset service lightHow to reset spanner on opel astra zafirahow to reset car with spanner lights on car
