Results 1 to 10 of 11
Thread: parrot 3200
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default parrot 3200
    having a few issues with my handsfree... dunno whether its the handsfree or the pairing with my phone (SE C902)..
    anyway, when the phone is connected, and I try to make a call... it isnt connecting through the stereo... on the display of the parrot I am getting a symbol of a note with a line through it... as if it is muted through the strereo..
    although sometimes its fine and I have no problems at all from it...
    then i can only use the phone through the earpiece!...
    any ideas guys or similar problems encountered?.. and if so any idea on the remedy?..
    I've tried to re- pair the phone but its still not fixed this bug!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you changed the profile to in car when it links. My SE C905 sometime answers but stereo still plays.
    profile changes automaticly i think when i get in the car..well, the handsfree icon appears on the phone anyway..is it worth manually swapping the profile too then?
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    THis is an issue Parrot are aware of and working on.
    I work for one of the 2 UK Parrot Distributors and talk to Stuart @ Parrot quite a bit.
    Hopefully won't be long
    Aparrently the early software version of the handset were fine then SE changed something and a lot of people are updating handsets by the SE update service and getting this fault happen after.
    hmm..ah thanks for the info..thats been driving me mad...it works for one call..and then the next it wont play sound through the stereo and you have to use the earpiece on the phone!
    doh..i just checked the title on the thread.. I have the Parrot 3100..ooops!
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Dwabo View Post
    No mate, it also changes to "In Car" profile. While the phone is connected, go into profiles and change it to "in car". You can then set it to Auto Answer and the rest of your options. Turn ignition off and it should disconnect, and change profile back to "Normal". If not change it manually and next time you turn ignition on it should change automatically.
    Jul 2006
    Colchester
    Same problem with all Parrots at present, C905 does it also!
    Bury cc-9060 Works fine with them though including reading out new text messages whilst driving
    (Bury distributor as well!)
    well..hope it is gonna be fixed at the SE end then ...as i have no way / idea how to update the firmware on the parrot unit..
    Vehicle : SRi
    Mileage : 137000
    You can download it from the Parrot site, and send it to your parrot via bluetooth from your lappy.
  1. Help with Parrot 3200
    By ianm59 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2010, 23:04
  2. parrot 3200
    By stuart bigboy in forum General items for sale
    Last Post: 5th September 2010, 18:15
  3. what iso for parrot 3200
    By rorycarz in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 20:49
  4. Parrot 3200 LS for £105!!!!!
    By Jamie in forum General Chat
    Last Post: 30th March 2007, 20:13
