Results 1 to 10 of 15
Thread: Nokia CK-7W
    Regular Member amiddleton's Avatar
    May 2008
    Hull
    Default Nokia CK-7W
    Hi All,
    I have a Nokia CK-7W (Bluetooth version) fitted in my veccy and everytime i get in i have to connect. Does anybody know how to set it to connect everytime. I have set my phone and paired etc it does it with a lot of phones.
    P.S just modded the Air Box and took the little black sleeve out.
    Cheers in advance
    Andy
    Regular Member dlm71's Avatar
    Cheshire
    Quote Originally Posted by amiddleton View Post
    Hi All,
    Cheers in advance
    Andy
    It is the phone that needs to be set to connect automatically! try unpairing the phone then pair the phone again using the password 0000, after it is paired it should give you two options, one of them will be connect phone automatically with out authorization, or word to that effect, select this option and as long as there is power to the car kit the phone will connect!!
    May 2008
    Hull
    Cheers David i have tried all this ????
    Surrey
    What phone have you got but as said above auto connect doesn't appear to be on?
    WGAF#5
    have you got a live ignition feed?
    sound like the kits loosing it's memory from what you are saying
    lots of the parrot kits suffer with a similar fate - do a search or look in the ice section theres plenty of info there
    you need to take a feed from the cigarette lighter
    good luck !!
    May 2008
    Hull
    Its a Nokia E65, i spoke to the guy who had it previusley and his worked fine. as i thought it could have been to do with the feed to it.
    Andy
    Cheshire
    What make of phone is it? i.e Nokia etc? might need a software update on the phone itself! or as daft as it may sound try switching the phone off then back on, if you have not already done so!
    Surrey
    So what have you got in Menu/connectivity/bluetooth/paired devices? & options settings? Is auto conn on?
    May 2008
    Hull
    It sure is m8
    Surrey
    Have you tried another phone?
    Try deleting the list of paried phones in the kit.
  1. nokia n96
    By stuart bigboy in forum General items for sale
    Last Post: 4th October 2009, 10:11
  2. nokia n80
    Last Post: 9th January 2008, 23:56
  3. Nokia N70
    By R13hard in forum General items for sale
    Last Post: 5th March 2007, 15:21
  4. Nokia HS-1C
    By Orka The Porka in forum General items for sale
    Last Post: 24th February 2007, 13:48
