Thread: Loud clunk/bang on full lock!!
    Jan 2009
    Kent
    Default Loud clunk/bang on full lock!!
    Hi all,
    looking for some advise on what this may be. Generally when parking in the street (therefore on full lock or thereabouts) I get a loud clunk/bang and the steering wheel vibrates slightly. It is just for a split-second but is obviously causing me distress, esp as I've just forked out for a new gearbox, clutch and flywheel!!!! They did something with the steering column (a minor repair at the time) as well.
    Any body have an idea of what it could be and how much? Its a 52 2.2 elite if it helps?
    thanks a lot
    Feb 2009
    scotland
    sounds like a drive shaft problem
    Regular Member macdad's Avatar
    Dec 2007
    East Midlands
    Quote Originally Posted by gtl View Post
    Hi all,
    thanks a lot
    Don't know if you've had any joy with this yet ,it does sound like the bearing on the front upper mountings goosed,easyish repair.
    Aug 2006
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If the noise happens when you're turning the wheel and sounds a bit like a spring, it could be the spring unseating itself,do a search for "spring seat mod",that'll explain it a bit better,HTH.
    Feb 2009
    scotland
    good point tyreman. The spring could be jumping around when on full lock.
    Regular Member barkzz's Avatar
    Id go with tyreman, sounds like the spring twisting in its seat, which eventually leads to it breaking in the same position.
    Get the car jacked up, and do a full lock turn. If you stay out of the vehicle and watch it, you should be able to identify it easier
  1. loud bang/clunk
    By andy_richmond in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2013, 12:33
  2. Clunk/bang when starting
    By Mike RB in forum Engine & Drivetrain
    Last Post: 7th October 2010, 11:16
  3. bang/clunk
    By *enery* in forum Suspension, Wheels & Brakes
    Last Post: 11th June 2009, 19:41
  4. Loud Clunk
    By liphook in forum Introduce yourself.
    Last Post: 16th December 2008, 21:52
  5. loud clunk
    By kristian in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2008, 16:45
https:www.vectra-c.comforumshowthread.php72858-Loud-clunk-bang-on-full-lock!!
bang on full lock
insignia wheel jumping on full lock
full lock clunk zafria
vectra c clunking on lock
loud clunk on full lock
vauxhall vectra bangs on full lock
vectra c clunk on full lock
full lock and loud bang car
panda 100hp suspension clunk steering
