Results 1 to 10 of 16
Thread: Alloys....Irrepairable
    Default Alloys....Irrepairable
    OK, my old mans vectra, the 2 rear alloys have some sorta stains on them, photos below - this is the state of them after he washed them. Can only guess its brake dust, only its like burnt/ingrained on, as when you run your fingers over the discoloured areas then onto the fine looking areas there isnt a change in texture.
    so:
    1. whats causing it?
    2. how do we get it off?
    3. how can we prevent it happening again,
    btw, the front alloys are immaculate, look like new.
    photos:
    cheers
    Have you had the car from new matey? I would guess that the wheels have no laquer on them.
    Have you tried some very fine wet or dry?
    An acidic alloy cleaner may get it off though, just don't keep using it.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    wonder wheels would take that of no probs mate
    Regular Member John H's Avatar
    Lanarkshire, Scotland
    Vehicle : Saab 95
    Trim : Vector Sport
    Engine : 1.9 TiD
    Try out some Wonder Wheels, on a small area first, that should bring them up like new though !
    Quote Originally Posted by david-bell
    even although it looks and feels ingrained in??
    might get some tomorrow and try it.
    Vehicle : Saab 95
    Trim : Vector Sport
    Engine : 1.9 TiD
    Took the words right out ma mouth David
    Yeah man that should shift it no probs
    Mileage : 000
    Would claying get it off. I have never tried, but just wondered.
    Regular Member Ian's Avatar
    York
    like already said - use an acidic cleaner with plenty of elbow grease - and rinse thoroughly. after that put polish on and wash reqularly using a non acidic cleaner and reapply the polish / wax such as autoglym.
    Mileage : 000
    Mind you I do try to treat the wheels with the same respect I do for the car paint, and wash with non acidic soap. and polish regularly, even if I don,t have time foe washing the car I do tend to wash the wheels. some one sugested to put a sealent on the wheels then polish them, something I will try next.
    Nicking Ya Dinner.
    Hi, I've had this happen a number of times, my own theory is that after the discs start to wear the pad is shaving micro filings and that is what the resulting gold effect is, in the past I've resorted to using a rough washing up pad to remove it, it does the job but does take the laquer with it, and after a few more miles the gold returns, run your finger along the top of the disc to see if the discs are worn, anything more than a slight groove and I'd say i'm right about the cause, if you want them top notch then you will have to replace the discs and have the wheels refurb'd, I dont think it's pads or pad quality as I use GM all the time, but i do notice as the original discs get to 50k it starts to happen, that or the laquer has burnt off by then leaving it unprotected, cheap fix is clean em as I said and spray them in, beware it's only a temp fix.
    Try Wonder Wheels 1st though, never know.
  1. Alloys
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2009, 23:21
  2. alloys some help please
    By paulvectrac in forum Handling & Braking
    Last Post: 29th November 2009, 16:20
  3. alloys again
    By paulvectrac in forum Styling
    Last Post: 30th May 2009, 23:03
