Thread: fuel filter What have i done wrong
    Regular Member forkieman's Avatar
    coventry
    Default fuel filter What have i done wrong
    Hello all you wise one`s out there.just did a filter change on my 1.9cdti 150 vectra which went very well untill went to drive home from brothers and the fuel low light is flashing all the time computer says 60 miles left and had had 1/4 tank when got there.I know i lost some fuel but not that much .Can anyone help how to it off if i can that is .Don`t like going to the stealers if i can help it .Many thanks for your help Lee(forkieman)
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    are you loosing fuel?
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    unless these fuel filters are cranked back up to the right tightness they p1ss out fuel. Was told this by a friend at Vx. Hes seen it happen before.
    Edit, normally it comes on when low, but once it gets down to 30mile range it then starts to flash
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    You may have left the valve open under the filter housing?
    But I also think it will not run if you did due to pressure.
    Do they have an electrical connection that you may have missed?
    Newcastle under Lyme
    Could it be an air pocket?
    coventry
    Default Many thanks for replys
    Hello all wise one`s .Mr stupid here tried putting more fuel in and it`s stoped flashing NOW.I now what your going to say well actually you can`t say it on here without getting in to trouble.But before i forget i did have plently of fuel in before i started only emptied filter.Anyway better go and hide somewhere many thanks for all your help .Must just say LOVE this forum always on here..Lee
    Sunny Dartmoor
    Glad you sorted it m8,it does help to fill it with fuel.........
    But for future reference (and only because I've been there and done it...) you only have to turn on the ignition and get the tank pump going to fill up and bleed the filter assembly. If you haven't tightened it properly, it WILL p*ss everywhere jsut under that pressure. No need to have the engine going or anything, just the ignition on and you should here the pump at the back winding up till it pressurises the whole system...
    I miss the taste of diesel from syphoning
    Quote Originally Posted by JSYSH466Y View Post
  1. Wrong fuel
    By drmak1992 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st January 2013, 21:47
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. fuel filter change gone wrong please help
    By stubopvectra in forum Engine & Drivetrain
    Last Post: 24th November 2011, 21:41
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. Tom Chilton puts wrong fuel in
    By PeteRs in forum General Chat
    Last Post: 12th April 2008, 20:05
