Results 1 to 10 of 11
Thread: Oil warning Light...
    Full Member Penfold101's Avatar
    confused Oil warning Light...
    Simple one this - what exactly does this mean?? Started coming on sometimes, goes off again when engine is restarted. No lo pressure warning, or warnings on the colour GID. Hard to see oil level as it was changed by me recently and is still fairly see-through, but if it does mean that the level is low, as I expect it does, then why doesn't this symbol appear in the manual anywhere....?
    south wales
    it will say in your vauxhall booklet mate in my 2.0t if the oil went low it would go into safe mode when the dealer told me this i started laughing and then 1 day my car went into safe mode checked my oil it was nr min so i topped it up and it was fine never seen safe mode again
    Mileage : 55000
    You will probably find that your oil level is on the minimum. Top it up as soon as you can.
    I shall top it up and see if it comes back on, thanks... I just find it odd that the manual wouldn't tell you what the warning messages mean, although it is obvious it's something to do with the oil...
    Still, it is Vauxhall after all....
    6 Post(s)
    Quote Originally Posted by Penfold101 View Post
    I just find it odd that the manual wouldn't tell you what the warning messages mean,..
    It does in mine (both my Jul 03 and Feb 07 editions).
    On page 38 of both books.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Mine displayed this symbol, but there was no limp home mode, and the oil level was low. A quick top up and all was well again. If the pressure warning light comes on, then you have got far more serious concerns.
    I topped it up and it hasn't come on since, but I still can't find it in my manual anywhere, and page 38 in mine is nothing to do with warning signs.......
    Regular Member MrT's Avatar
    Near Durham
    I've seen it twice - once way back when on 3k miles after which I had them do an oilchange anyway (never liked the idea of doing 20k on the original stuff!), and again on 29k miles, which is the first time I actually needing to top up the oil - both times the dipstick level had dropped to 1/3 up from the bottom mark. In the last case I also noticed a slight drop in performance, which went away on topping up, but nothing like a limp-mode - I've had experience of the limp mode in Cavs before, and it's just not funny when the engine dips to about 1500rpm all of a sudden, just because a bit of dirt gets on a sensor!
    Belfast
    That's different to my car, it has a seperate light for that up to the right side of the dash. It comes on with the rest of the lights before you start the engine.
    Germany
    if it goes out when you start the engine, it means it is due a service.
  1. Warning Light
    By chrissy white85 in forum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
audi 80 tepalo lempute
opel signum warning lights
