Thread: Creaking/Griding/Clicking from front offside
    May 2008
    Ipswich
    Default Creaking/Griding/Clicking from front offside
    Hello there.
    I need a little help with regards to some strange noises coming from the front o/s wheel area.
    Apologies for boring you but a little history (essay) first
    The car had a slight (very slight) noise going over speed bumps when I bought it at 12k miles, even at low speed. I thought it might be the anti-roll bar links so persuaded the Dealer (who thought I was hearing things) to replace them under warranty at 15k. The noise reduced a little but still something present.
    I then replaced the suspension all round with Bilstein B6 shocks and Eibach Pro-Kit springs. When doing this I noticed that the nut holding the o/s strut stud into the turret bearing was loose!! Anyway, I put this down as the cause of the knocking. All has been well ever since until I finally got around to getting a 4-wheel laser alignment a month ago, at around 33k miles.
    A couple of weeks after the much needed alignment was done I noticed a clicking noise coming from the front o/s. This was only present after a long motorway journey (70miles or so) and only noticeable at low speeds. After cooling down/resting and on shorter trips the noise is not there. When I first noticed it I took it straight to the dealers but having waited for the mechanic to become available the car had 'cooled down' a little and the noise had gone. So I dropped him back off feeling slightly embarrassed for dragging him out to listen to nothing!!
    After each successive long journey (I do about 100miles home then back again at weekends) the noise reappears. From the sound of it I thought it was a CV joint although the noise was present when coasting, accelerating and braking and only audible at low speeds. I can also feel it through the pedals.
    This morning I pulled over briefly into a lay-by and stopped, with the familiar noise there again (but getting slightly worse). I then turned the steering wheel with the car stationary and it made the creaking/crunching sound. To me this would rule out the CV joints but I could be wrong. I am also noticing a slight knock/click when rocking the steering wheel right to left when stationary, as if there is some play somewhere.
    It seems that any movement in the suspension, whether it be up/down or when steering causes this noise and only when warm at the moment. Could this be Tie-rod/tie rod ends, the turret bearing or something more sinister?
    Any help or ideas would be greatly appreciated and thanks for reading!
    Clinton
    Regular Member Craig1985's Avatar
    harwich essex
    im getting the exact same problems with same set up and after 4 wheel tracking? did you find a cure?
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    I would be looking at getting them inner tie rods and track rod ends checked, although as you've just recently had a 4wheel alignment done the garage should have checked these before aligning the car. No good aligning the car with these worn. Alternatively could be a problem with the steering rack itself, the inner tie rods are the more common problem though.
    You say you feel it through the pedals? Well that would point more to being wheel/brake related. Possibly a wheel bearing? Might also be why you only hear the noise when having done some miles and all hot? If it was wheel or brake related I would expect the noise to fluctuate with speed etc but you never mentioned this??
    Interesting to know what is the culrip and cause of your problem is. Top strut bearings?
    Bri.
    Regular Member teera2uk's Avatar
    Oct 2007
    Lincs
    Correct me if i`m wrong guys but there is a modification for plastic tubing you slide onto the spring coils does this not correct this problem
    Regular Member vectra sri dan's Avatar
    Oct 2006
    newcastle-under-lyme
    i have the similer sound like a ticking noise at slow speeds when warm . the sound is like a brake noise its not my pads as only half warn but i got a feeling its the disks as got a fair lip on them with all the rusty crap you get on top of the disk .
    therefore i think this is the problem and dose it when warm as the brakes expand just enough to make the sound as if press the brake it goes .
    going clean the top edge of the disks whip pads out clean up and i sure this will cure the problem .
    oh mine done 40k 2006 sri and heavy foot on brakes .
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by teera2uk View Post
    There is indeed mate and it sounds like this is the problem that th OP has. They part was a modification made by VX and they are available from your dealer for a couple of quid
    Oct 2007
    Lincs
    yeah i had this problem but the dealer said they didnt have it in stock and there are various sizes depending on thickness of spring he also said that most of the time the guys in the workshop just get ordinary tubing and cut it to length so thats what i did and worked a treat now all they need to do is sort the problem with springs snapping
    Regards
    Oct 2009
    wolverhampton
    i had the smae problem with my 2.2dti and i also checked on auto data which says to fit the plastic sleeving on the bottom end of your springs it worked a treat they cost about 2 quid each and come in 2 colours you need the blue ones
    good look mate
    this is a known problem on vectras
  1. Front offside coil spring
    By Tank988 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2011, 20:54
  2. Droning noise from the front offside
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 22:22
  3. Clunking from offside front when braking
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 22:12
  4. Creaking/clicking noise
    By Gogs67 in forum Bodywork & Interior
    Last Post: 12th April 2006, 12:17
Tags for this Thread
