Results 1 to 3 of 3
Thread: Engine Warning Light - EGR valve
    Regular Member ExclusivDoug's Avatar
    Windsor, Berks
    Default Engine Warning Light - EGR valve
    Okay so my warning light came on a couple weeks ago and according to the handbook and a lot of guys on this forum it's associated with the EGR valve being clogged up with carbon deposits. Today i removed the EGR valve and low and behold it was extremely clogged with the mucky black cr*p. I cleaned it as well as i could sprayed a good dose of carb/fuel injection cleaner and it looked so much better than it did before.
    So the cars running so much better than she did when i picked her up but the warning light is still on.
    A friend of mine whos in the motor trade seems to think the on board comp needs resetting because its recorded the fault. Has anyone else had this issue and is it connected to another problem?
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Disconnecting the battery for 10 mins may reset the warning light.
    Windsor, Berks
    Problem has now been resolved, the light switched off on a short journey and hasn't been back on since. More importantly the drive to work was sublime!! between 50 and 80the power delivery was so much more smooth.
    Im not sure exactly how the egr affects the power delivery but im glad i took the time to clean it out.
  1. Vectra EGR valve - recurring warning light
    By corriganpaul in forum Engine & Drivetrain
    Last Post: 16th April 2012, 23:01
  2. replaced egr valve and service warning light
    By tyler boy in forum Diesel Engine related
    Last Post: 15th March 2011, 20:57
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. EGR Valve/engine management light
    By sleeper341 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 13:07
  5. engine warning light
    By spooney in forum Petrol Engine related
    Last Post: 20th January 2009, 18:05
