How do I attach the VXR decals kindly donated by signumboy?
Are these the same as airfix models with a bit of warm water or do they require something else?
Also where is the best position for them links to pics if poss
nope you just position them... then rub them firmliy with a clean cloth ,then peel the top coating off , as for positioning you just follow the curve of the brake calliper round...not sure if i have a piccie ,will have a look see![]()
once you have them fitted give them a coat of clear nail varnish to help seal them on,i did it on mine and they are still spot on after 18 mths![]()
