Results 1 to 10 of 15
Thread: 1.9 120 cdti turns but won't start
    luton
    Default 1.9 120 cdti turns but won't start
    the car turns over and has fuel to the injectors, verified by removing the return pipe.
    i've borrowed a scan tool (uiftech u480) but it won't communicate so i assume its too old to talk to the CAN system properly, it hangs on the read screen.
    engine icon light is on but spanner is not.
    can anyone suggest what i should check as i'm frustrated as hell
    thanks
    preston
    Disconnect battery for 30 mins then reconnect would be my next move
    luton
    yes, that was one of mine, too. left it off overnight but no joy.
    Admin plasma's Avatar
    On the Forum
    187 Post(s)
    Engine : 150
    Mileage : 74000
    had a thought here.. that reader should work... so maybe a engine ECU fault? Get someone to try another reader or tech2 to see if they can communicate with engine ECU..
    EVERYWHERE
    Possibly just bad connection to ECU from loom.
    luton
    i managed to get hold of a different code reader, says there are no DTC's stored.
    luton
    took it to the stealer this morning. apparently it hadn't been in to have the handbrake recall done so they were happy to have it straight away.
    luton
    bad news, the high pressure pump has failed, going to cost £1000 to supply and fit, including all the time spent on diagnostics.
    i could get a remanufactured pump but i can't fit it myself and i'd have to pay to move the car elsewhere.
    i've decided to pay the stealer to do the work, at least it will be fully warranted and if it so much as coughs i will take it back.
    now i remember why i hate diesels so much.
    EVERYWHERE
    No doubt about it,diesels are a hell of a lot more complicated than they used to be.
    Did you have a tuning box/remap fitted or was it standard ?
    luton
    the car is standard, has 69k on it and is serviced by vx every year.
    just goes to show that things can and do break regardless of how they are looked after.
  1. Vectra turns over but will not start
    By TI7ANIC in forum Engine & Drivetrain
    Last Post: 24th August 2011, 16:32
  2. HELP! Car wont start, Engine turns over.
    By CDTI120SXI in forum Troubleshooting
    Last Post: 23rd July 2011, 13:57
  3. Radio turns on every time I start the car
    By FazerMonkey in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2010, 19:04
  4. 1.9 cdti turns over but fails to start
    By swifty776 in forum Engine & Drivetrain
    Last Post: 9th January 2010, 22:57
  5. 1.7 CDTi with CR1 on 21 turns
    By AJA in forum Diesel Engine related
    Last Post: 12th April 2006, 08:19
vauxhall vectra c 1-9 cdti starts but wont run
