Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: 1.9 CDTi (150) air box mod... worth doing?
    Regular Member MCD's Avatar
    NE Manchester
    40 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default 1.9 CDTi (150) air box mod... worth doing?
    Read this a few times in sigi's and specs etc! Whats the advantage? Is it worth doing? Whats involved? Is it like the 3 pipe mod on the vec B?
    Cheers for any imfo!
    Mike
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Quote Originally Posted by MCD View Post
    Is it worth doing?
    In a word.....YES!!
    If you take the top off the air box ant take the filter out you will see a detachable ''flap'' in the bottom of it. Pull this out and bob's your uncle.
    Doing this greatly reduces the flat spot low in the rev range, and it just seems to pull better.
    Regular Member darko2301's Avatar
    Croatia
    well i have a 150 cdti too and i cant believe it is that simple?
    is it a part which should be simply taken out?
    can it have any consequences?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Very very easy it will take you 3 to 5 mins
    wales
    Quote Originally Posted by pricey View Post
    In a word.....YES!!
    got to agree gets rid of flat spot and pulls better
    Regular Member PAULMAC77's Avatar
    warrington
    ive done it and to be honest i dont feel it's made any difference..
    oooooop north
    ive done it on the 1.9 120 and have noticed a HUGE difference to the driveability!!
    the power is smoother, picks up better and makes the car ALOT more driveable!!
    B..
    Regular Member mattolly86's Avatar
    oxfordshire
    just done it to mine and its more torque down low smoother and just feels right
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    well worth doing,you got nowt to loose as said it dos feel a lot better bottom end
    give it a go you know you wonna go on go on go on.......Now pick your keys up turn around and walk out the front door to your car, plip your key fob,open drivers door reach down to drivers foot well pull bonnet release,walk to front of your car lift bonnet undo airbox lid,remove air filter,look inside the airbox see offending item,give it a quick tug...plastic bit not what you was thinking you can save that when you get back from test drive after the mod or better still get the wife to do it lolreplace air filter,and lid close bonnet back to drivers door open drivers door get in insert your key into ignition turn key till you hear engine turn over, put into first or if auto select "A" and away you go with that cheshire cat grin on your face
    cheers mark
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    Amazing! Thanks guys! Will give it a go when I've sorted wifes breakfast in bed!
  1. is it worth blanking with new inlet manifold (cdti 150)
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 20:35
  2. vectra cdti elite 3.0 v6 is it worth buying ?
    By matthughes73 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 08:10
  3. Thinking of Selling Up - SRI CDti 150bhp - What is it Worth?!
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 16:53
vectra c 120 v 150 airbox
air box mod zafira 150
1.9 cdti airbox mod benefit
How to get more air into vectra c 1.9
luftfilterkasten mod signum 1 9
