Results 1 to 10 of 22
Thread: knocking heater dial???????
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Default knocking heater dial???????
    evening guys and gals, noticed this evening that when i turn my heater dial (the one to choose hot or cold) to the coldest point it seems like something is turning and reaches its furthest point and can't go no more so as it trys to continue turning it makes a knocking noise for a second or two. i think it may be that when i changed the led's in that unit i may have oved the knob position so will try moving it back tomorro just wandering if there could be something else.
    Nov 2007
    telford,
    Nov 2007
    telford,
    Mileage : 000
    Does it make the noise when you press the "recirc" button to it,s off position, a sort of clicking noise that lasts for abour 10 seconds.?
    Nov 2007
    telford,
    not sure haven't tried it. she's had the car so hopefull lunch time 2day i can have a look and a play,and with the car.lol
    Surrey
    A bump in 19 mins?
    Surely you have put the knob back wrong when changing to LED'S.
    Nov 2007
    telford,
    that'll be cause when i created the new thread within 5 mins the forum updated so no one would have seen the thread, unless they searched for it on the search bar.gonna have a look in bout 20mins when she gets home from work.
    Surrey
    BTT.
    You taken it apart yet?
    Nov 2007
    telford,
    doesn't seem to be a prob with the control unit and the sound is coming from behind the stereo console where i'm assuming the heater matrix is or what ever it is.i can hear this part moving as i change the heater's position from hot to warm to cold, then at the dials coldest point is still when i hear this knocking sound( like a mechanical part moving but something is stopping it moving any further so sounds like a cog is slipping).this is the same in all fan positions with or without aircon also with or without air re-circulation,i am still getting very nice hot air and also very cold air still.if i leave the dial in its coldest point after i hear the sound then turn the ignition off i don't get the sound again,but when i turn the ignition back on the noise comes back again for the same length of time about four quick knocks.
    Surrey
    Did this happen as soon as you changed to LED's?
    As you change the temp dial it adjusts the mixed air valve servo. Might be worth checking the servo lever.
  1. Clicking noise when turning the heater dial
    By AntSSSS in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2013, 20:33
  2. prob with heater fan speed dial
    By bobk1 in forum Bodywork & Interior
    Last Post: 22nd March 2011, 02:31
  3. heater dial illumination
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 22:59
  4. dial change!
    By vec-cal in forum Styling
    Last Post: 8th May 2010, 23:14
