Results 1 to 10 of 17
Thread: powerfold mirror
    Regular Member signum03's Avatar
    worthing
    Default powerfold mirror
    evening all, quick one, i have a signum(03 plate) i know when you lock the car and hold the fob the mirrors fold but is there a function on the unlock where they fold back out again?if you hold the unlock button in ,the windows open, just seeing if it can be done really! also i have been told you can put a function in to automatically lock the doors after 20mph is this right?if so how do i do it.cheers
    Regular Member WKD-mcc's Avatar
    glenrothes
    look at the how 2 section,theres a how 2 on locking the doors.sure you hold the lock button on the fob at the same time as the lock or open button on the driver door.the how 2 will tell it better
    If you have the folding mirrors as standard i.e. factory option then as you say they fold when you hold the fob lock button. When you then unlock from the fob they then should simply fold out again.
    Have you retro-fitted them? If so, then that problem is a sign of incorrect programming or not the right door modules.
    worthing
    no its factory fitted!
    In that case there's a problem. Do they fold/unfold from the rocker switch on the driver's door switch? (make sure neither mirror button is depressed.
    worthing
    yes and work perfectly
    Definitely a problem then - maybe the key needs reprogrammed or something in the door module needs reprogrammed? Certainly a problem there and probably a dealer job only. Given your location you're welcome to pop over this way (Eastbourne) if you want to see if anything on my Vaux-COM can help. They've recently said that the next version of the software will be able to program door modules so I can get a Beta version of it and have a looksey. I'd also be able to see if reprogramming the key would help at all - unlikely though as that's all related to the immobiliser/CIM etc, not the mirrors.
    worthing
    thanks for offer, would pop up if wasnt so busy at work, funnyly enough i bought this signum from eastbourne had many probs since then on, and he worked for vauxhall shoreham!
    worthing
    aaa
    Kent
    would I be right in saying all cars with electric mirrors would have the folding mechanism in place already?
  1. mirror cover & mirror glass
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 11:27
  2. Looking in the mirror
    By fenderguitar in forum Quick Photo Album
    Last Post: 6th July 2009, 19:29
