hi all i have a light that has come up on the rev counter displaying a light bulb with a exclamation mark inside it ive checked all the bulbs and there all ok . does anyone know what it is?????????????
I thought it meant that either a bulb has blown or there is a fault on the lighting circuit... Or a brake problem/warning, low pads???
its a picture of a light bulb so i dont know what it is
The same happened with me last week just before a bulb blew, I changed my side light bulb and it went away.
how did you know to change ya side light was it just a guess ??
On my screen it told me which bulb was out, so I just followed that. I did find tho if I turned the lights on when the bulb icon appeared it would disappear and not come on untill I turned the lights off.
this just happened to me on the way home, all bulbs seem fine tho. will be checking again tomorow or waitin for one to go in the next few days
mine came up saying check left brake light, and it had gone but what the car does is uses the side light bulb as a brake light till u replace the blown bulb, if its a brake light thats gone if u chech the lights you will probly notice one side the brake light is the top one and the side thats gone will be lower down on the lamp as its using a different bulb until u replace it..
this happened to me a few times before xmas. finally the bulb went completely. i treat these as a warning that a bulb is about to fail!
