Results 1 to 10 of 16
Thread: Do i OR Dont i?
    Sittingbourne
    Question Do i OR Dont i?
    Question time ...
    with the 45F/40R PI springs (obv them measurements are for lowering standard suspension setups) on a 56 reg 1.9cdti (150) SXI suspension setup....
    Do i OR dont i need to get shortened shocks??
    i know lowering it 30mm is usually fine for standard shocks etc. which with this kit... if the sxi is 15mm lower, with these springs its going to go down 30F/25R... is that fine for the shocks? are you able to get away without changing the shocks as the SXI setup has shorter shocks than the lower spec models?
    Cheers for your help
    Dave.
    Sittingbourne
    I meant SRI dont even know what car i drive now! lol.
    and... does anyone get the camber adjusting bolts? is the tyre wear after lowering them alot worse on the inner edges?
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You might need shorter shocks with those springs even though your SRi runs lower shocks anyway( im sure l'll be corrected if im wrong ) and as to wheel alignment MOST definately get it done after you lowered it as it will wear the tyres out HTH.You want to have the 4 wheel alignment done though.
    Regular Member Robbie69's Avatar
    Mine is an SRI and lowered on 45/40 pi springs with standard shocks, work a treat. I haven't bothered with the camber as I am waiting for my tyres to wear out! I will then and I would if I were you!
    Regular Member jb-redbull's Avatar
    warrington area
    Trim : half leather
    Engine : 2.0 turbo petrol
    Mileage : 149,000
    how long have you been running yours on this set up now mate lowered pi 45f\40r springs and standard sri shocks thinking of doing this to mine.
    about four months, no uneven wear yet but i don't drive hard! Get it done, harsher ride but the looks more than make up for it, £110 transforms the looks IMHO!
    Robbie,
    I'll swap my springs for your exhaust!!!! LOL
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Had those springs with stock shocks for 18 months had no problems yet
    payney has gone -65 with standard SRi shocks and his has been fine for 2 yrs or more .... well at least 2 M.O.T'S !!!!!
    his are PI springs ...
    He had them with a view to be -45 but sinse I've had mine lowered by -65 we have found its the same !!!
    Belfast
    Surprising that people are running standard dampers on lowered springs. The dampers are the weakest part of the Vectra's suspension. My back ones are starting to feel a little wobbly after 20k...
    I've lowered every Vauxhall I've had, and either replaced the dampers immediately, or had to replace them a few months later due to saggy handling.
    The SRi I think is low enough, so I'll probably upgrade the dampers before the winter, probably Koni FSD or Bilstein B6.
    Aug 2007
    Great Wyrley
    I tend to change when needed and mine hasvtn needed doing yet so no point.
    The shocks are 15mm shorter than stock so its onyl a 30mm drop on them wich isnt much
  1. Mot do i or dont i
    Last Post: 30th May 2012, 13:53
  2. Do i or dont i
    Last Post: 15th May 2012, 13:34
  3. Do i or dont I?
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2009, 21:27
  4. Fuji GP Warning spoiler, dont look if you dont want to know!
    By rushy in forum Motorsport / Formula 1 etc. chat
    Last Post: 12th October 2008, 13:23
  5. I really dont want the Vec to go - but will it have to?
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 00:17
