Thread: chrome strip along the boot
    Regular Member WKD-mcc's Avatar
    glenrothes
    Default chrome strip along the boot
    i'm 100% positive av read threads on here that have said the chrome strip along the back is plastic took it off the day to c/c it but turned out to be metal.never sprayed anythin metal,always been plastic.so what primer would a need for that,a metal primer are the chrome strips easy enough to paint?
    Carnoustie
    Think you will need to wet'n'dry sand it first to take the shine of it, otherwise the paint will peel off
    Ronnie
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    you would have to rub it down good and proper m8
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    As said run it down with Wet and Dry to make it dull and then spray it with Acid Etch Primer and then normal primer and you know the rest. Acid Etch chemicaly eats into the metal to make it stick good and proper
    glenrothes
    thanks alot lads,be taken this info into consideration when the time comes
  1. chrome boot strip
    By titley1976 in forum Bodywork & Interior
    Last Post: 7th February 2011, 18:02
  2. chrome boot strip off?
    By simplesi in forum Styling
    Last Post: 15th May 2010, 11:22
  3. chrome boot strip
    By sristeven1 in forum Parts for sale
    Last Post: 14th May 2009, 18:51
  4. chrome boot strip
    By SRIsteven in forum Bodywork & Interior
    Last Post: 7th July 2008, 19:33
  5. Chrome boot strip
    By wstwatson in forum Styling
    Last Post: 5th February 2008, 21:02
