Results 1 to 10 of 25
Thread: Oil Catch Tank
    Newcastle under Lyme
    Default Oil Catch Tank
    Any ideas.
    My mate put one into his westfield and although I got the gist hoping some can fill me in in english. and whether this can be fitted with any benefit to a 1.8i Petrol
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i had one on my old c20xe astra to stop oil serge round sharp bends and islands at speed (stopped clouding the place with smoke)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The breather pipe that comes from the head feeds oil vapour into the intake manifold using the vac caused by the intake. If you look at your throttle body you will see it covered in crap, most of this is from the breather pipe. You put a catch tank in between the breather and the intake to "catch" all the oil and stop it chocking up your intake. Due to emissions this vapour has to be burnt off so just venting it to atmosphere is not really advisable. Not to sure on the 1.8 but on the 2.2 the really do there job as 2.2 TB's get really covered in crap. HTH
    dont create much smoke going round corners that I know off. Do I take it this would be nothing more than a cosmetic mod
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Post 3 mate.
    cheers I was mid post. If I fitted one it wouldnt do any harm and although not as effective as on higher spec it would still serve a function - to a degree
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Yes mate, but not much, have a loo at your TB butterfly and behind it, if there is loads of crap then bang one in. Its not going to do any harm. Guys make them out of coke bottles.
    What on earth is a TB Butterfly? Doubt ill be as cheap as to put a coke bottle in his was polished steel.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Throttle body butterfly mate. All they are is a container with an input at the top and another input at the top again. The vapour comes in, liquids drop to the bottom of the bottle/tank and the vapor is drawn off at the top. Most tend to have a visual inspection slot in the side, a bit like a kettle to see how much oil is in there and when to empty.
    we'll continue this tomorrow not to be rude. Work at 7
  1. oil catch tank.
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 00:32
  2. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  3. Oil catch tank
    Last Post: 23rd December 2011, 16:04
  4. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  5. oil catch tank
    By spidermonkey in forum Engine & Drivetrain
    Last Post: 16th August 2011, 14:40
