Thread: More 2.2 help please...
    Wales, UK
    Default More 2.2 help please...
    Hi all, As you may know from previous posts, 2.2 z22se - coolant/gasket issues..
    Anyway, question - Take a look at these pictures below. Im no great mechanic but like to have a go at it. Are the little squares at the edge, oil wells that I assume the oil runs through ?
    Only one of the 6 wells is covered in mayonase - Do you think this means that the crack, broken gasket has broken at this particular place ?
    What are your opinions on this ??
    Main reason for taking the cover off today was the car started sounding like a diesel. Can clearly see that the chain is slack so I assume the tensioner has failed. Car drove ok to where I parked it overnight so dont think its jumped any teeth thankfully. Will get a large socket/spanner tomorrow and whip the tensioner out to inspect.
    Your help is much appreciated!!!
    All the other little well things seem nice and black !?!? The worst well obviously corresponds to the sam well in the rocker cover, consequently has thrown a bit of mayo throught the breather into the TB induction pipe....
    Regular Member poves's Avatar
    Dec 2007
    lancashire
    Mate , that tc looks as baggy as a wizards sleeve
    Dec 2007
    south wales
    vauxhalls are wierd not to sure about yours but my dad has a 55 plate corsa with only 20,000 miles and it has creamy oil cap,went to see a gsi today and that had cream on the oil cap i think it must be condensation but obviously not in your case there should be some 1 along with more knowledge than me soon
    Wales, UK
    Thanks guys, Baggy as a wizards sleeve....First thing to make me laugh after the face ive got on at the moment due to my car !!! Thanks !!!
    Wales, UK
    Any takers ? lol
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    You want to go on the 2.2 forum mate, some great advice on there mate. z22se.co.uk. HTH
    Regular Member ballan22direct's Avatar
    Feb 2009
    isle of lewis
    Quote Originally Posted by poves View Post
    Regular Member benny's Avatar
    Feb 2006
    dudley
    to me it seems to be normal condensation in the bottom right hand corner of the engine bellow the oil filler cap...if it isnt looseing any water i would say dont worry to much all you need to do is prob take the car on longer trips and get it burnt off or change the oil a little more regular .... the chain looks bad ... i would fit a complete kit (but i would say that wouldnt i lol ) .........
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Feb 2006
    dudley
    sorry just read your other post about it looseing water ...how much water does it loose .? are you 100% the leak isnt external take a peek at tha back off the engine under the car near where you see the exhurst pops out and see if the water pump isnt leaking ... also check the radiator aslo check the carpets and see if there wet try and lift them and check the under side as the water can some times not show on the furry side ...good pllace is up behind the glove box where the carpet begins try and shove ya hand down and feel ...... if ti is the head gasket the job isnt too big a job but it is if the head needs a skim or is craked ...
