Thread: 20 amp battery constant feed
    Fife
    Post 20 amp battery constant feed
    Am fitting a tow bar on my vectra and am needing two 20 amp constant live feeds for the 12s (AUX) plug for my caravan.
    Is there any spare feeds in the boot?
    Either that or i will have to run a cable to the battery.
    Cheers for any info.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well you could tap into where the electric seats suppose to be.. (check the manual)
    Regular Member mat100edt's Avatar
    south coast
    electric seats wouldn't be 20amp supply. your far better comming straight from baterry with a decent size cable with an inline fuse.
    Would these connections not be standard if the correct towing kit is used? I thought they were basically plug and play, with a bit of Tech2 jiggery pokery afterwards to enable the multisocket connection?
    Surrey
    F13 in the boot is a 20A supply for towing equipment.
    Regular Member 30ltr nutter's Avatar
    dunstable
    there is i plug and play connector in the boot just need to buy the tow bar loom from vx i think it is about 40.00 but it needs
    to be switched on with tec 2 for the system to work
    Fife
    I have just received the towing kit for my vectra from the local vx dealer.
    The standard 7 pin socket was approx £40.00 all in,
    The 13 pin euro socket is approx £55.00.
    I got the 13 pin version and as you say they are just plug and play apart from the tech 2 part, and the fact that the reverse wire is not connected into the wiring harness for the towbar for some reason.
    Many thanks to all who replied, much appreciated.
    Dave
  1. where can i take a constant +12v feed from for front parking sensors?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2012, 20:11
  2. Rad fan on constant
    By Gavin2.6 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 16:17
  3. Not constant revs around 3K
    By Boz657 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 15:55
  4. Constant speed
    By mspvxr in forum Comedy & Humour
    Last Post: 21st September 2008, 20:18
