Results 1 to 10 of 24
Thread: Gsi 3.2 help
    south wales
    Default Gsi 3.2 help
    went to view a 53 plate gsi today and the dealer wants £2800 but i have a few questions,
    1.should it be breathing out off dip stick hole when dip stick removed while engine running
    2.is it worth £2800 it has 112000 miles with service up to 70000 and the body work has a few scrapes and think it needs antiroll bar bushes,m.o.t till august tax till april
    3.is there anything to look out for when looking for a gsi cheers in advance all
    south wales
    one more thing whats the realistic fuel consumption on a 3.2
    Regular Member poves's Avatar
    lancashire
    Think the dipstick issue is normal as long as it's not spewing.
    I'd start at £2000 , then no higher than £2400
    Avoid the automatic gearboxes as they are prone to fubar
    Realistic mpg 18
    south wales
    just a tiny bit of smoke come out but the engine sounded sweet the other thing was when the traction control kicked it i noticed the trip computer flicker is that normal cheers mate
    lancashire
    Not too sure on that one , they do have some bad electrical gremlins so be careful , mine was an auto so can't comment on tc as I didn't have that option.
    south wales
    how much is road tax for a 3.2
    Regular Member j13hdb's Avatar
    Nottingham
    Tax was £205 last year. If it's blowing smoke and electrics looking dodgy avoid it like the plague! No service history after 70k? Should have timing belt at 80k but really 40k to be safe- has it had 1 at 80k? If so you need to change it again- £400ish. MPG- at 70 on a run approx 37ish around town 23ish hammering it 7mpg!
    Be very careful with a beast like that or it could bite your wallet very hard!
    Maida Vale
    My advice would be to leave it well alone. It'll need a cambelt change immediately, and that's a biggish job on the 3.2 and it has to be done with the use of a the cam-locking kit (unlike other engines, it's impossible to do it without it) and this narrows your choice of people/garages that will do it. Secondly, it's missed several oil changes, which in itself is an issue, but on the 2.5/2.6/3.0/3.2 GM V6's it's worse because it'll guarantee that the oil breathers will be blocked by now, so they need cleaning (not a 5 minute job) and the blocked breathers either will shortly, or already have, blown the cam cover gasket(s).
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    I get 27.4mpg from mine and I have a lead foot.
    Tax is £210/year increasing to £215 from April.
    Cheshire
    Vehicle : Insignia
    Cam belt change not too bad. Due every 80k miles. Ive just been quoted £275 for mine.
