Results 1 to 3 of 3
Thread: Sump plug location? 3.0 CDTi
    Dec 2005
    Bristol
    Default Sump plug location? 3.0 CDTi
    Call me lazy for not crawling around on the stones in the drive but any ideas on where the sump plug is located?....sounds like a silly question I know but on the Laguna a huge protector plate had to be removed before access could be gained to the plug and two of the fixing bolts were sheared....that's Renault engineers for you,(overtighening), talk about a long job to change the oil...then replace said bolts, my bro' in law was not a happy badger. He's offered to do the change the weekend and it would be nice to warn in advance if it's likely to be problematic or straightforward.
    Mileage : 000
    If it is like my 3.2 V6 then it should not be a problem the sump plug is at the back of the sump, you can see it if you get down low enough, you might not need to jack the car up either, looks a simple job to do. I shal be doing mine when the warenty runs out.
    Dec 2005
    Bristol
    Quote Originally Posted by ed taylor
    If it is like my 3.2 V6 then it should not be a problem the sump plug is at the back of the sump, you can see it if you get down low enough, you might not need to jack the car up either, looks a simple job to do. I shall do mine when the warenty runs out.
    Thanks for that, hope mine's the same, like I said the Renault was 'orrible to get to. Mine is still in warranty too but i've mixed oils when topping up and just to be on the safe side i'd prefer to get it out and put fresh in of all one viscosity/make...a little paranoid I suppose but i'll feel happier!
    Regards...........
  1. Sump Plug location
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 17:17
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Stupid sump plug 19 cdti
    By Mopar Man in forum Diesel Engine related
    Last Post: 11th February 2011, 23:05
  4. Serviced today, 1.9 cdti (150) Sump plug
    By robblue2x in forum Engine & Drivetrain
    Last Post: 6th September 2009, 12:08
  5. cdti sump plug and washer?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 23:40
