Thread: General SatNav Install Questions
    UK
    Default General SatNav Install Questions
    Hi
    Someone I know has just bought a new Vectra C (the one with the facelift) which has a SatNav Cd player installed. They had a Corsa C before and I have the cabling for the corsa to iso connections.
    Could someone tell me:
    • Is a new Cd player necessary for adding a subwoofer to the current system or has it got aux connectivity?
    • If not, do I need to buy another cabling convertion set for the Vectra (I have the quad-lock cable for a Corsa)?
    • Will a Corsa C facia fit into a Vectra?
    • Is it a hard job fitting a new Cd player in a Vectra?
    • Are there any Cd players out there that will still make use of the LCD display inside as it seems a shame for it not to be used
    Dan
    Oct 2006
    Wellingborough
    CD70 has no aux in or out.
    Yes, you'll need a line converter or an amp which allows high level inputs.
    a fascia adapter for an aftermarket head unit? no.
    no.
    no.
    UK
    Hi
    I forgot about high level inputs on amps.
    Luckily the amp I will be using has got some.
    Just need to check for a third pair of speakers wires on the wiring loom.
    Dan
    Northampton, UK
    Doesnt the latest CD70 have the AUX out? So you can plug your Ipod in???
    Chester
    Quote Originally Posted by n_hudson View Post
    2008MY added Aux. in so from around September 2007 it should have it.
  1. Couple of questions (Satnav and phone)
    By Chuddy in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2009, 09:31
  2. Two general questions...
    By luckyluke in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2008, 11:13
  3. kenwood dnx7200 install questions
    By barracuda in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2008, 17:14
  4. Satnav retrofit questions
    By paulw563 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2008, 19:28
  5. Pioneer Install Questions
    By bennyk in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2007, 17:51
install sat nav in vectra c
