Thread: v6 CDTI and coilovers
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default v6 CDTI and coilovers
    Has anyone got Coilovers on their V6 CDTI? If so what?
    These seem a good price...
    http://cgi.ebay.co.uk/SPAX-RSX-COILO...1%7C240%3A1318
    But is there a difference between whats needed on a saloon and hatch? ( I have a hatch).
    Also would the V6 not need a different setup to others due to the front end weight? These say they are ok for all engines?
    The main reason for going for coil overs is the ability to alter the ride height depending on what im using the car for. Does anyone know how easy they are to set up?
    Thank you in advance for all your help and all comments welcome.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i believe "big phil" has these coilovers on his V6.
    they are easy to fit and change the ride height, but each time u change the height you really need to re do the tracking etc.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Fair enough.
    Anyone any suggestions for a set with easy height adjusting?
    I know it sounds like an odd request, but most of the time i would want it as low as possible, but a few times a year i carry a large load, so would need to be able to lift it for that.
    Thank you
    Stephen
    you could raise the rear easy enough without havin to have the tracking done, i believe.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Any idea what effect this would have on the handling?
    Presumably if i did it once loaded so it matched the front height wise it would be ok?
    Thank you
    handling shouldnt be affected really that much, cus u wont need to change the height that much as the springs are quite stiff on the coilovers.
    also adjustin the height takes a few minutes each side. The wheels dont have to come off to adjust.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Excellent,
    Thank you for all your help.
    One last question...
    Any idea how the compare with FK's?
    Thank you again
    ive never used spax.
    Ive got KW coilovers on my vectra now.
    And ive used FK's in the past (on other cars), I would of had FK's on the vectra now, but when i was lookin at gettin coilovers they hadnt made a set for the vec c yet.
    playing with spanners
    i have fk on mine the the backs are a bit tricky to lower on the car ,
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Thank you very much
    Stephen
  1. Coilovers....
    By ben2996 in forum Handling & Braking
    Last Post: 27th August 2012, 20:22
  2. Best coilovers for gsi
    By GT3071R in forum General Motoring Chat
    Last Post: 16th June 2012, 21:58
  3. 2007 Vectra Sri CDTi. Coilovers, VXR alloys...
    By benw456 in forum Cars for sale
    Last Post: 14th March 2011, 08:49
  4. Coilovers for £300?
    By vxpenfold in forum Handling & Braking
    Last Post: 26th December 2010, 12:22
  5. coilovers!!
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 22:14
