Results 1 to 10 of 13
Thread: Engine gets waaarm...
    Norway
    Default Engine gets waaarm...
    The temperature here in my area is now around 0 these days, and while driving the temperature shows around 70-85 , but if I park somewhere and let the engine run, the temp goes up to almost 95-100 within 4 minuts... It stays at 95-100 until i starts driving again, and then goes down to 70-85.
    Is this normal ?
    Going to my dealer this friday with a small list of "to-do".. I have 3months waranty, so everything I find wrong will be fixed for free
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    do the fans kick in ok?
    Norway
    I haven`t checked... haven`t let the engine run that long, and get that hot.. I guess I should hear the fan if i`m standing outside the car, or opening the hood .. ? At witch temp do they normally start?
    Maybe a lot of stupid question.. long time since I had a Vectra, and also this "new"...
    Regular Member CDXI_2003_AUS's Avatar
    Melbourne, Australia
    As big rich said, i'd check the fans, shouldn't be getting that hot. It's a bit of a common fault for one of the 2 fans to stop working. If they are ok, check your thermostat and make sure you have antifreeze/antiboil in.
    Belfast
    95C is normal for a petrol engine.
    Norway
    Quote Originally Posted by _ZS_ View Post
    And when I start driving again, it`s normal to get down to 70-85 ? I guess it`s just me thats all nervous .. new car and in love with it
    Will try to let it get warm again, and listen carefully if the fans are running.
    Maybe we run different therostats over here, but mine doesn't reach 95C on a 35C day sitting in traffic for 5 minutes, let alone if the outside temp was 0!
    Belfast
    Quote Originally Posted by VectraCClub View Post
    Yes, it's normal for the temp to go down when driving (stick your paw out the window at 70mph and see how warm it gets!)
    You likely won't hear the fans running, the only way I know mine's going is a slight vibration on the steering wheel when sitting in traffic (and I do mean slight).
    Belfast
    Quote Originally Posted by CDXI_2003_AUS View Post
    Mine's at 95C by the time I've got a mile up the road in the mornings, even in -5C temps. I'm guessing they run them hotter over here to give a better heater output.
    Norway
    I see..
    I was at my dealer today and asked about this heat-"problem", and it was normal. came home and let the engine run for one hour or so, and the temperature did stay on 90c or something.. so.. nothing to worry about
    As I said to the dealer; "Sorry about all the questions.. new car, and I`m nervous something is wrong with it.."
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
