Thread: Laptop Keyboard
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Question Laptop Keyboard
    Does anyone know how to get the degrees C symbol on an IBM laptop keyboard. I know it's Alt + 0186 on a pc keyboard (using numberpad to the right) but the laptop is not having it!
    Got a document to finish and this is holding it up!
    Cheers,
    Paul.
    Feb 2007
    North west
    ◙ write Deg.C - much quicker. Sorry. Amazing what you find out on here.
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    just use that keymap or something its called... or copy / paste this ℃
    Regular Member John3v36's Avatar
    NI
    is it not in the insert symbol in micro. word?? failing that superscript the 'o' and then caps C!!
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    have a look at this page,it will tell you how to do a º and also how to switch on the number pad on a laptop ,if yours dont switch on using fn+f8 mine was fn+num lock http://www.northlite.net/ps/numpad.htm
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by bertbuckie1 View Post
    - called Character Map under the Programs>Accessories>System Tools. That's on XP BTW. If you're using Vista then I'm not sure if that has the same?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Just chaecked and 'tis indeed in the same place on Vista.
    I didn't even know it existed.
    Here, there and every where!
    vista is the same. Also Alt +0186 works for me too
    Interestingly Alt 0186 works if I use the numeric keypad, but if I use the numbers above the QWERTY bit then it doesn't! So what solorider said above may me what the reason is - i.e. you need to press a couple of keys to activate the 'numeric keypad' on the laptop. Assuming that is that you've got a numeric keypad on the laptop where the numbers are next to various letters? That's probably more faff and the Character Map way I'd reckon is much quicker.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Sorted it, cheers lads for the replies. It's fn + num lock and hey presto it's 80ºC !!!!!!!!!!!!!!!
  1. keyboard advice
    By chris1804 in forum The 'Off Topic' room
    Last Post: 6th November 2012, 11:59
  2. Samsung laptop keyboard
    By rob warrington in forum The 'Off Topic' room
    Last Post: 23rd November 2011, 22:23
  3. Could all of those not apt to using a keyboard...
    By John LE in forum The 'Off Topic' room
    Last Post: 27th September 2010, 21:17
  4. New DELL Keyboard
    By spoons in forum Comedy & Humour
    Last Post: 23rd May 2006, 19:28
  5. Yamaha keyboard (music)
    By cpt slow in forum General items for sale
    Last Post: 10th February 2006, 18:11
