Thread: Castor camber settings
    Fife
    Post Castor camber settings
    Does anyone know if, 1 the camber is adjustable front and reaer, and 2 the settings for the castor and camber front and rear (where applicable) for my 2008 vectra 1.9cdti hatchback.
    Cheers.
    Dave.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    1, yes they can be adjusted
    2, dont know the setting's i'm affraid
    imho i would take it to a specialist place and get any nessesary adjustment done on a decent system so it is spot on...
    hth
    Midlands Mod Shop - NFFC.
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Quote Originally Posted by ditchp View Post
    hth
    Pro-grip bonnybridge falkirk mate..
    topclass
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    I didnt think the camber was adjustable on the front.
    I dont know any of the settings either. but like said above using a pro is best option for gettin setup properly.
    Apr 2006
    Suffolk
    There are different set ups for all models of 1.9 cdti's.
    It depends on what suspension you have. There is either Standard, Sport or Rough Road.
    Most setups are for the first two.
    Fife
    Do you have the contact number for that company in falkirk please mate???
    Quote Originally Posted by goonturbo View Post
    Canal Bank Estate, Unit 8
    Seabegs Rd, Bonnybridge, FK4 2BP
    01324 810111
    Fife
    Many thanks for the name and address will give them a call.
    Dave
  1. bad camber!!
    By wullie-t27 in forum Handling & Braking
    Last Post: 9th November 2012, 21:06
  2. castor and camber
    By kevinjm in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 18:26
  3. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  4. rear camber settings
    By tditony in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 19:28
  5. Replies: 7
    Last Post: 20th April 2007, 21:11
caster opel vectra
vectra c caster
