Results 1 to 10 of 22
Thread: i have a clunk
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Angry i have a clunk
    on monday clonking appeared,it only happens when pulling off ,forwards or reverse,sometimes you also get a clonk when braking,there are no visual signs something is wrong but i have not had chance to get the car jacked up,there are no issues once moving,anyone have any ideas?
    the clunk sounds like it is coming from the passenger side and to some extent can be felt through the floor
    Regular Member signum03's Avatar
    worthing
    does it clunk when going over uneven road or speed bumps?
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by signum03 View Post
    nope,only when pulling off
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    checking the cars mot and service history,my car failed an mot on 08/03/08 saying "nearside front lower suspension arm has excessive play in a ball joint" ,the mot was doe by nationwide autocentres,on the same day i have 2 bills showing £42.40 for steering and £147.31 for suspension.i would say they fitted a pattern arm as a genuine arm is that price without labour,but it should not of failed within 17k miles,it was done less than a year a go,hopefully i may be able to get in contact with nationwide and get their invoice number and get it replaced under guarantee (that is if it is the arm)
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Radiator mounts???
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    well the clonk is coming from the passenger side footwell,i cannot find what is causing it,the only thing i have not been able to check the n/s engine mount,all suspension mounts look ok,anti roll bar mounts and link rods are ok with no play,would the subframe move on the back edge? this happens when you pull off and also to some extent when braking,it does not do it when moving nor when easing off the throttle and flooring it.
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    i have done a video,the noise is worse nearer the end after the wheel screech (not me lol),it may be the spring as there is a related noise,the spring does look ok,is seated where it should be and the car has just passed an mot
    Regular Member gromit's Avatar
    Cumbernauld
    Gearbox mount or bush?
    Regular Member swainey's Avatar
    Newtown Powys
    nice clunk i wish i had 1 where did you get it from and how much did it cost
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by gromit View Post
    checked the rear mont and it is ok,as is the front mount
  1. clunk
    By matt.d in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 19:12
  2. Big Clunk
    By Ben_ in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2011, 15:03
  3. Clunk..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 21:53
  4. clunk from steering
    By idobigmls in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 07:13
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
vectra c rear clunking noise when reversing site:www.vectra-c.com
