Thread: REALLY werid power output (2.0 DTi)
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    confused REALLY werid power output (2.0 DTi)
    heya,
    okay this is really odd i work all week and dont drive the car till the weekend and one friday it dident start. RAC out and supprise supprise it started first time. revved it a bit and it was okay. its fine now he recons it was a stuck EGR valve.
    But now a new not problem its just weird. when i first start it the car has no power untill 2200 RPM then oh my god it ripps your neck muscles off. also the noise of the engine becomes alot louder all of a sudden. only happens a couple of times then after starting then its fine steady power from the bottom to the top as normal.
    any ideas what might be stuck somewhere?
    Will
    West
    A good place to start would be remove the inlet elbow & clean it out, clean the boost sensor which is attached to the elbow while you are at it.
    It's a real messy job but worth it, you could also go down the route of taking the egr out & de coking that too.
    hth
    Cambridgeshire
    Similar thing with mine almost like it has a 2nd cam or powervalve. Let me know how you get on and if it cures as hoping to have a day to sort the car soon and this is high on the list.
    Cheers adrian
    Belfast
    Mine used to do that (Astra 2.0DTi). There'd be nothing, nothing, nothing, then it'd pull like hell spinning the tyres in the dry, leaving a huge plume of pure black smoke.
    Mine only did it once in a while, usually when warming up on a cold day. Never did figure out what did it, as it only did it once every few months.
  1. 2.2 SRi single output to twin output (direct) conversion
    By waqas in forum Petrol Engine related
    Last Post: 18th January 2010, 02:10
  2. What is the Power output of CDTi 150
    By johnny1983 in forum Diesel Engine related
    Last Post: 12th January 2010, 17:37
  3. engine output power/torque + pos upgrade?
    By mick 1986 in forum Diesel Engine related
    Last Post: 14th April 2009, 21:42
  4. Wot Power output? 2.0dti
    By brianjamesreed in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2007, 19:31
