Thread: Radiator heating ?airlock? HELP
    Regular Member littlesxi's Avatar
    Oct 2007
    derby
    Default Radiator heating ?airlock? HELP
    I fitted a new radiator to my veccy 1.9 cdti 120 on sunday as my old one had a crack in it,took it all apart fitted new rad and all went together without a any probs,checked it all for leaks and was fine.filled the system back up cap off,bleed nipple out,heaters full on and so on and left it to run on the drive for about 30 mins and the temp gauge didnt read at all so took it for a quick drive,the temp gauge seemed to go up the faster you go and come down when you slow down,about 3 miles down the road the engine management light came on and the car juddered a bit.got it home and topped the system up a bit and the management light has stayed on since and the temps seem well dodgy.
    has anyone got any ideas?
    thanks
    WGAF#5
    there are probably 2 bleed nipples - you will probably find another on the rear bulkhead
    i imagine there is still air in the sytem somewhere
    Oct 2007
    derby
    does anyone know if there are 2 bleed nipples on this if so where is the other 1
    WGAF#5
    Quote Originally Posted by littlesxi View Post
    what vehicle and engine mate ?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    its the 1.9 cdti mate 120 bph
    Oct 2007
    derby
    someone must of had a problem like this before,any help will be appreciated...
    East Midlands
    Hi M8..this is the procedure for re-filling according to the haynes bible...
    Fill the system by slowly pouring the coolant into expansion tank until it is up to filler neck.
    Using a small screwdriver ,lift up the wire clip securing the left hand heater hose to the heater matrix pipe stub,and disconect the hose from the stub.
    Additionally,on 1.9 ltr engines,open the bleed screw in the coolant pipe above the exhaust manifold.
    As soos as coolant begines to run from the heater matrix,push the sucuring wire clip back into position on the heater hose end fitting ,then push the hose back onto the matrix pipe stub.
    Ensure that the wire clip securly locks the hose in position.
    On 1.9ltr engines,close the coolant pipe bleed screw as soon as coolant emerges.
    Hope this helps.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. airlock or ??
    By mikecoz in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 18:17
  3. Central Heating/Radiator HELP Required please - ASAP!
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 4th January 2011, 14:24
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  5. new central heating radiator
    By garvey in forum The 'Off Topic' room
    Last Post: 5th February 2009, 21:33
how to bleed coolant on vectra c www.vectra-c.com
vectra c heater air lock
vectra c heater hose
air lock coolant vectra c
vauxhall zafira 1.9cdti heater hoses bleed nipples
vectra c sri 1.8 coolant airlock
vauxhall vectra air lock
how to remove an airlock from a vectra 1.8
Vectra 1.9 cdti engine is heating
vauxhall insignia coolant bleed nipples
vectra c 1.8 2004 air lock problem
vectra c 2.2 coolant bleed
vectra coolant air
vectra coolant air screw
