Results 1 to 10 of 11
Thread: Tech2
    Regular Member dankidd's Avatar
    May 2008
    Newcastle
    Default Tech2
    Does anybody have a tech2 system? I need my emissions light reset coz its all on the time due to having the cat converter changed... and i refuse to fork out another 40 quid to the same garage to put it on tech2 again?!
    North east HQ
    I would have thought, if the work you've had done is causing the light to come on then it should be upto the garage to sort it out.
    Quote Originally Posted by chunkster View Post
    is that not part of the work to reset a fault? ..
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Just disconnect the battery for 20-30 mins mate, that will clear the fault.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    that should sort it m8
    Melbourne, Australia
    Or you could just leave it - if the problem has been fixed the light should turn off anyway.
    May 2008
    Newcastle
    Ta )
    Boldon
    Disconnecting the ECU or battery wont clear the fault fully, emmisions related fault codes are stored in the ECU permanetly until erased with diagnostic equipment or after 30 clean engine starts (on some ECU's) in much the same way as an engine control map is permanently stored, irrelevant of voltage supply.
    Disconnecting the battery simply resets the canbus and some other systems, it also resets the ECU so it re-boots (on some ECU's)
    If you need the fault erasing permanently feel free to call in to PDtuning, it shouldnt take us more than 10 mins.
    Paul.
    VIP-Member ianwat23's Avatar
    Gateshead
    Vehicle : Vectra Sri 120 navi
    Trim : Sri
    Engine : 1.9 cdti 120 bhp
    Mileage : 38550
    Ive got a Memoscan Diagnostic machine which does engine fault codes on all obd2 and can bus systems from 2001 petrol and 2004 diesel.
    If you need any info just pm me and ill try and see what I can do
    Ian
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    would a tech 2 clear my problem of the steering wheel ! mark light. my power steering fluid was low and when i topped it up the light has stayed on since. had it to a bloke with this hand held thing but it never cleared the fault light. don't know if it was a tech 2 but he said it cost about £3500 and it plugged in under the ash tray in the front. power steering is perfectly normal though no actual problems. its frustrating when i payed the bloke £20 to look at the light and reset it...if anyone could help it would be appreciated.
  1. Anyone have tech2?
    By krazylegz in forum South Central (ARO - matty2fatty)
    Last Post: 21st July 2012, 21:38
  2. tech2
    Last Post: 21st December 2011, 23:39
  3. tech2 help
    By Rickiw in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 21:05
  4. Anyone have Tech2
    By chrisdownes in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 12:09
  5. tech2
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2008, 13:24
