Results 1 to 10 of 15
Thread: Bulb blown warning ON, all bulbs ok??
    oooooop north
    Question Bulb blown warning ON, all bulbs ok??
    any ideas chaps??
    B..
    Regular Member MrT's Avatar
    Near Durham
    could be a tell-tale that a bulb is about to properly fail - some folk have mentioned an intermittent bulb failure warning on and off a couple of weeks before the lamp actually blows.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It could be a rear as the brake light is partially illuminated if the sidelight goes check carefully look for symetry!
    Regular Member MarkiQon's Avatar
    South Shields
    I've had the same but all lights working up to now
    oooooop north
    Quote Originally Posted by paulhb View Post
    yea ive been RIGHT through it, checked EVERY bulb, checked EVERY connection, wiggled wires, and flicked all the switches, and all still seems the same!!
    the ONLY thing that doesnt work is the nearside rear fog light, i have had it in bits and it isnt wired up so i guess its not supposed to work!! (all ideas for making it work gratefully received )
    im thinking it COULD be a bulb on its way out, and am going to keep a VERY close eye on it for the next few weeks!!
    B..
    Full Member chunkster's Avatar
    North east HQ
    how strange, my brother rang me today with exactly the same problem!!!
    Wayne -
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    .....are any connections anywere in the loom slightly wet ?
    I've had this three times now
    It's first warning that the electrical resistance i a bulb is higher than the tolerance, and this suggests it is near to failure
    You can leave it until it fails completely
    The only way to find it is to replace each one for a new bulb until you work out which one is near the end of its life
    If you have the Driver Info Centre then the warning message will give you an indication of which ones you need to check
    If you only have the warning in the Engine Control Centre, then you need to switch on all the bulbs and then walk round the car and visually check
    Regular Member James Stewart's Avatar
    Hampshire
    Quote Originally Posted by bungle666 View Post
    B..
    this should help http://www.vectra-c.com/forum/showthread.php?t=41022
    May 2008
    Tyneside
    Rear nearside brakelight is not required to work, check out this post http://www.vectra-c.com/forum/showthread.php?t=72098
  1. bulb warning light on....but no bulbs appear blown
    By rjw in forum Troubleshooting
    Last Post: 12th October 2010, 01:18
  2. Blown Bulb Warning...
    By VikBee in forum Troubleshooting
    Last Post: 7th August 2009, 17:46
  3. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
  4. Blown Bulb Warning Help??
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 00:15
  5. Blown bulb warning light on dash??
    By Genterz in forum Troubleshooting
    Last Post: 9th August 2008, 11:10
vectra dash warning light bulbs ok
bulb out light on my vectra but all bulbs are ok
light bulb warning light vectra when all bulbs are ok
