Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Problem with tuning box!
    Default Problem with tuning box!
    Just had a problem with the box. I'd had my tuning box working perfectly for about a week, but decided to turn it up a bit to see if I could get any improvement.
    So last Sunday I decided to turn it up a turn or 2. I turned it up another 2 turns and it was running fine and felt even quicker. Now on Monday i was making a trip to London for work. Half an hour into the journey the car stopped going into the forward gears, meaning gears 1, 3 and 5. It just would not go into them at all. The backward gears were perfectly fine. I was on the motorway so i was it wasn't too bad.
    Half way into the journey i stopped and turned it down to its previous setting and 1 turn lower and set off. But it still wouldn't go into the forward gears. When i got to work in London I took the box completely off and all the gears worked again thankfully.
    Now whenever i put the box on the car doesn't go into the forward gears. I need to try turning it down even further however it was working fine on this setting for a full week.
    Has anyone experienced this before and why is it happening?
    Thanks for the help guys,
    Rich
    Jan 2006
    Dalriada
    very strange
    i cant get my head round as to why the box would affect the gearbox??
    Yeah, I thought so too. Strange that it is fine when i take it off. You'd think if the gearbox was malfunctioning it would be permanent, but its not. Anybody else any ideas why this might be happening?
    Admin plasma's Avatar
    On the Forum
    272 Post(s)
    Engine : 150
    Mileage : 74000
    Isnt April 1st over and done with?
    I'm mystified mate. A tuning box doesn't effect the gearbox at all.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    no i have not here of that before but
    what type of box is it
    is it plug and play
    is it hard wired in with spade connecters
    there could be a problem with the loom
    The only reasons a manual box would not select the 'front' gears but will still select the 'back' gears can only be adjustment of the linkage or engine mounts allowing the engine to move too far thus lenghtening the travel required to select the gears..The 'front' gears rely on the linkage coming far enough backwards from the gearbox, whereas the 'back' gears push the linkage forward..
    I don't think you can blame this one on the tuning box..It has no connection to the manual boxes..I think it's time to pay the Stealers a visit
    If the problem is replicated by putting the box on, and isn`t hthere when it`s off it is clearly the box. I would suggest it has something to do with our old freind canbus ? Doers seem very strange though I thought at least the gearbox wasn`t fly by wire ??
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Sounds like a mis-aligned gearbox linkage to me.
    Though I stand to be corrected as that gearbox is purely a mechanical system. No electronic shifter or anything!!!
    I'd put money on it that it's not the tuning box. All the box does is ask the ECU to send more fuel to the common rail, the gearbox has nothing to do with it.
  1. Problem fitting tuning box
    By 2.2 oil burner in forum Diesel Engine related
    Last Post: 5th December 2010, 20:15
  2. DTUK Tuning Box Problem
    By 2ltrT in forum General Chat
    Last Post: 2nd May 2008, 21:48
  3. Strange Radio Tuning Problem
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2007, 22:45
  4. tuning box problem
    By john barnes in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 12:03
  5. Tuning Boxes - Problem power?
    By Andy in forum Diesel Engine related
    Last Post: 21st September 2006, 17:00
