Results 1 to 10 of 16
Thread: anyone know what this means
    Regular Member ptrehearn152's Avatar
    norfolk
    Default anyone know what this means
    hi all, i've got 2004 2.2 dti ellegance estate, every time i switch on the ignition i get this symbol on the trip computer screen which i confirm on the wiper stalk then never see it again (until i switch ignition on again), i've had a look through the handbook but can't see what it means, i know it's something to do with the alarm/immobilser/door locks, is it normal to get this or is it telling me there's a fault? if it's normal am i able to get rid of the symbol so that it does'nt come on every time i switch on?
    thanks in advance.Attachment 16877 above the icon it says 'check safegaurd' sorry you can't see it for the flash.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    fault with the alarm?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    its check safegaurd meaning you have a fault with your alarm system when you arm your alarm does the red light flash for a few seconds then start to blink or does it stay solid then blink?
    Mine use to flash for a few seconds after arming the alarm then blink so i looked at my sensor by roof light made sure it was all plugged in and secure and refitted seems to of cured the problem
    Tech2 would find the fault HTH
    Common culprit is as bigmac said - the ultrasonic sensor connection up by the roof light getting loosened. Certainly first thing to check.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    it maybe someone has disconnected the siren ...can be found left hand side of boot.
    there is a mod to use the car horn as the alarm,but this causes that signal you have showing HTH
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    try undoing the car with the Key and see if you get the siren or the horn blaring
    norfolk
    Thumbs up
    thanks everyone will give it a look tommorow and let you know what i find.
    norfolk
    hi again, just had a look at the motor, all connections to sensors secure and tight, when alarm is set the red light flashes for a short while then goes to a slow 'blink', when locking on the key all indicators flash once then again when the key fob is pressed again, all indicators flash once when unlocking with the key and again when unlocking the passenger doors, when alarm is set and door is unlocked with the key indicators flash and siren sounds as soon as the door is opened, as far as i can see it does everything that it should but when the ignition is switched on i still get 'check safegaurd' on the dash. anyone got any further ideas before i start spending money for someone to hook it upto a code reader?
    Surrey
    My last vectra (pre facelift elegance) did this after some body work. turned out to be condensation in the connector for the door located by the hinge. Disconnected and reconnected and fixed the fault
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Try putting some tape around bonnet sensor so it holds it down,bonnet sensor is by top of drivers strut then check to see if when armed the red light should be solid then blink
    If it still flashes then your problem might lay else where
  1. Anyone no what this means
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 13:46
  2. does anyone know wot this means
    By neilybhoy1888 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2009, 22:30
  3. Anyone knows what this means????
    By johnny in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2008, 09:08
  4. can any one tell me what this means?
    By moles-sri in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2008, 21:22
  5. Anyone know what this means, or dare to try it.
    By v6boy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 10:56
