Results 1 to 10 of 13
Thread: wobble bolts advice
    Regular Member swainey's Avatar
    Newtown Powys
    Default wobble bolts advice
    can anyone give me advice on wobble bolts?? iam lookin at a new set of wheels but to get them to fit i need wobble bolts.
    any advice would be welcome good or bad.......
    Regular Member ballan22direct's Avatar
    isle of lewis
    I've just ordered some. As far as i can tell from what i've been reading there sound.
    Newtown Powys
    bump
    Regular Member hagga's Avatar
    kingswinford
    wobble bolts are ok as long as wheel pcd id +/-2mm (5x108-112), but you may need to check spigot diameter too, these can be bored out or spacers made to suit
    Newtown Powys
    can anyone shead any more light on this subject.....
    Regular Member P3tchy's Avatar
    Milton Keynes
    I used the wobble bolts with my snowys and nearly lost one of them (wheel) as they kept coming loose. Changed them to standard ones asap.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    a freind used some with vaux rims on a bravo and they were fine for him
    kingswinford
    Quote Originally Posted by swainey View Post
    what is it you need to know?
    Newtown Powys
    i never heard of wobble bolts before just trying to find out about them
    if i buy these wheels i dont want them to come off
    and if members have used them befor i like to hear there views on them
    kingswinford
    I've been using wobble bolts for the last few months and had no probs, Basically they are identical to a normal wheel bolt but the tapered washer will move up to 2mm so if say you wish to use 108 or 112 pcd wheels (instead of vx 110)the tapered washer will line up correctly with the tapered recesses on your wheels thus holding the wheel correctly. Not using wobblebolts will result in misalignment and damage to the wheel. there are locking wobble bolts available too though if you are using spacers (if the new wheels et is way off) you will have to use locking wobble nuts and a stud
  1. Wobble bolts on a 3.2 v6??
    By Couttsy in forum Styling
    Last Post: 7th May 2012, 23:09
  2. wobble bolts and what wheels can i fit?
    By Timkel in forum Handling & Braking
    Last Post: 5th July 2011, 20:00
  3. Wobble bolts - are they safe
    By Lao in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2010, 18:37
  4. Wobble bolts
    By Ziggy in forum Handling & Braking
    Last Post: 23rd February 2009, 14:49
