Thread: Brake light problem
    May 2007
    Cheshire
    Default Brake light problem
    I have got a warning message - check right brake light.
    I have checked it, and the wrong light is coming on. On the estate, the outside lights are the brakes. This is what is happening on the nearside, but on the offside, it is the inside light coming on (the one on the boot lid, not on the rear wing).
    Any thoughts ?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    bulb out and another bulb taking over the broken ones place?
    [Ex]Admin Duncan's Avatar
    the car has a system where if a brake bulb goes then another light takes it's place and works as the brake light - on the estate it must be the light in from the brake light. Once you replace the brake bulb then it'll go back to normal.
    Mileage : 000
    I bet the light that is now lite up is one of the side lights on the tail gate. All the bulbs on the rear are 21watt, and are dimmed down to 5watt if they are a side light. But as said about will be subsituted as a brake light (21watt) if needed. All cleaver stuff.
    Regular Member badback's Avatar
    Runcorn
    That's damn clever.
    May 2007
    Cheshire
    Ed - you are right - the 'temporary' brake light is the side light on the tailgate. It is clever isn't it !
    Next job = new bulb.
    Thanks for your replies
    11 Post(s)
    Quote Originally Posted by dave200 View Post
    Use the non working rear fog light bulb. It's there to be used as a spare.
    May 2008
    Tyneside
    Thought I had a rear fog light out as only the right hand side works. Reading the manual and Big Daves coment looks like only the offside fog light is suposed to work. Strange having a light fitted but not active.
    11 Post(s)
    You only need one working rear foglight for an MOT.
    http://www.motuk.co.uk/manual_110.htm
    Discussed many times here. Only one wired up so as not to totally obscure and lessen the view of the brake lights for anyone following you.
  1. Brake and Side Light Problem
    By itdaveh in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 22:51
  2. Brake Light Problem
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2012, 21:07
  3. Brake light Problem
    By DavyC in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2010, 18:29
  4. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  5. Brake light problem?
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 10:08
vectra c rear brake lights on all time
vectra brake light bulb problems
vectra brake light problem
right hand brake light fault on vectra
faults with brake lights on vectras
brake light problem vectra
