Results 1 to 10 of 24
Thread: Oil and mayonnaise
    Regular Member MLC's Avatar
    uk
    Default Oil and mayonnaise
    I was checking the oil on mother in laws car today and noticed some white gunk around the oil filler cap. First thought was 'head gasket', but the car doesn't lose coolant or overheat and drives normally.
    Can condensation cause this or should she be worried? The car is used daily and covers reasonable mileage, so no short, stop-start journeys.
    Regular Member gromit's Avatar
    Cumbernauld
    My car does this if you do short journeys but it clears when you drive it for approx 15/20 miles. Dont think its something you have to worry about. Just pull out the dipstick if the oil on that looks okay then it should be fine.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I checked the wifes corsa yesterday and saw the same thing around the filler cap - BUT no oil leak, no smoke, no coolant leak and Oil looks reasonably healthy on the dip-stick.
    I put it down to a dodgy cap letting moisture in, as like you say, the car runs fine daily
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yes - moisture in the PCV system causes this, especically when cold and not been on a long hot run...
    Give it a damm good thrashing up a dual carridgeway (no more than 70MPH please ) and get the engine nice and hot - will go..
    A
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    the best thing to do is a compresion test to be on the safe side
    [Ex]Admin Duncan's Avatar
    It's just likely to be moisture Paul, and will be more likely to form if the car doesn't get driven at operating temperature for a reasonable length of time. A nice long run will help but if the car doesn't get those then you may want to consider slightly more regular oil changes.
    Mileage : 000
    Unless there is any other problem with the engine. I would say it is due to short journey,s. Both my Vectra and Larisa,s Vectra get this "gunge" in the engine. I have removed the oil filler pipe and put the oil filler cap in it,s place. That cured the problem. On Larisa,s there is an oil separator fitted. But I have to clean it out from time to time as it get full of this mayonase stuff. A good blast on the motorway will soon shift it for a while.
    Belfast
    Don't you know Hellmans use old 8v Vauxhall engines on short trips to produce the world's supply of mayo?!?
    Mileage : 000
    Quote Originally Posted by _ZS_ View Post
    And some of the Ford engine,s too.
    uk
    Car is run daily on the motorway, that's the cause of concern.
