Thread: One Wiper Broken what is the law?
    worcester
    Default One Wiper Broken what is the law?
    Only the driver's side wiper is working, the other is sitting at the bottom of the screen doing nothing. I assume a broken linkage but my question is can I drive the car for a week in that condition or does it need fixing ASAP to keep within the law.
    Feb 2007
    North west
    law will state something like "system for clearing screen of rainwater for safe visibility" and I would say having half the screen not clear is an offence. However if you Rain-x your screen you hardly need wipers for the first couple of weeks anyway. Screen self clears, use rain-x you know it makes sense.*
    * I love rain-x as you might have guessed.
    Regular Member DKM's Avatar
    May 2008
    Suffolk
    When at work if one of the wipers on a bus is'nt working it has to be fixed because its a defect that VOSA would pick up on.
    Domestic cars are not as strictly looked upon but its most likely illegal.
    You would have to be unlucky to be seen in a week though.
    WGAF#5
    if its fitted then it has to be working - anything that can or could cause an obstrcution to your visibilty is detremental to your driving - if you had an accident - you would be hard pushed to get your insurer to pay out
    every vehicle on the road must meet a certain standard of road worthiness as set out by The Road Vehicles (Construction and Use) Regulations 1986 and The Road Vehicles Lighting Regulations 1989
    It is an offence if your windscreen, windscreen wipers and washer bottles are not in good working order
    or maybe this would be a "lighter thought" if the police turned up at your door and told you that someone had killed a loved one because their windscreen wipers were not working but they decided to drive it anyway, how would you feel -
    could be considered as driving a vehicle in a dangerous condition by police
    especially if driven in the wet! no method of clearing spray from the road or other vehicles.
    rant over
    worcester
    Thank you all.
    I will be onto the garage ASAP to sort out when it can be booked in.
    Aug 2007
    liverpool
    Default Cheap fix for broken linkage arm
    JUST USE A ZIP TIE ON IT VERY CHEAP AND LASTS LONGER THAN THE NEW LINKAGE YOU WILL HAVE TO GET FITTED
    worcester
    Andy K.
    What do you mean about a zip tie?
    Is it easy to fit, I am a complete novice unless it's got a computer.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Zip tie it to the other wiper so that pulls it up dont do that not safe at all
    Aug 2007
    liverpool
    Default Zip tie
    Ball joint on linkage disengaged zip tie will hold it back in joint -is completely safe went through two linkages at £70 just for the part before mechanic told me common fault and gave solution
    Apr 2008
    Liverpool
    Quote Originally Posted by andy k View Post
    Really? wow learned somthing new everyday mate will keep that in mind if ever it happens to me
  1. broken wiper stalk
    By triple595 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 19:54
  2. Windowscreen Wiper broken?
    By mattricketts in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2010, 12:42
  3. Broken Wiper Linkage(s)
    By GazVXLINE170 in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2007, 18:17
