Thread: Engine Oil
    Regular Member amiddleton's Avatar
    May 2008
    Hull
    Default Engine Oil
    Just been informed by VX that the oil that goes in my engine is extra life and £10 a litre, what is this stuff and can it be bought cheaper.
    It's 5w30 oil GM-LL-x-025
    Providing the oil meets that specifcation then you can use any supplier
    Ironically, the GM stuff is usually cheapest
    5 litres from the Parts Department will cost you about £30, so best to buy that and supply it yourself at servicing
    Not sure what engine is in your SRi but if it is a 3.0 V6 CDTI then you will need 2 bottles and for any other engines best buying two anyway
    The spare you can then use for topups until next service
    May 2008
    Hull
    Thanks M8, its only the wii little 1.8 so will i need 10 ltrs.
    Andy
    Northampton, UK
    10 litres! I thought my 2.0T only used 6 litres?
    http://www.vectra-c.com/forum/showthread.php?t=15115
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Just had oil and filter changed in my 1.8, takes 4.5 ltrs. 5 ltrs cost me £33 from stealers
    Quote Originally Posted by n_hudson View Post
    Yip, you will need two for the 2.0T
    However, it would be prudent to purchase two as you can then use the second one for topups; cheaper than buying single litres until the next service
    Most of the engines will only need one 5 litre pack
    Z18XE
    4.25 litres
    Z19DT
    4.3 litres
    Z22SE Z32SE
    4.75 litres
    Z22YH
    5.0 litres
    You will then need two 5 litre packs for
    Z20NET
    6.0 litres
    Y30DT
    7.25 litres
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
