Results 1 to 10 of 11
Thread: The next strange thing to happen
    Regular Member gary k's Avatar
    West Mids/Worcs
    Default The next strange thing to happen
    History:
    Car broke down after not revving, AA man said DPF
    VX said EGR, changed and then said DPF
    Part ordered, but car would drive upto about 3k rev
    Spanner light comes on but drives ok, in safe drive-home mode
    Workshop tech said may regen if 45min 3k is achieveable
    Wednesday: took it for a spin, 30 min 3k revs, still spanner
    Friday: when I arrived home from work (a 20 minute journey at 30/50mph) I could smell burning, so I looked under the car and the DPF was glowing red! like a neon tube red!
    Saturday: I could drive the car at any revs and no spanner light only problem is, there is still a fault as the mpg is now mid 20's and when i put my foot down and rev upto 4k, its down into single figures so it'll still have to go back in to be looked at but suspect they won't know what to do as theres no spanner light to diagnose fault code
    Any ideas on the low mpg? is the DPF still knackered? is it the lam.sensor? the egr needs a clean?
    Any help gratefully received!
    asdasd
    sorry but just wanted to know what does dpf said for? thanks
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Diesel Particular filter mate
    May 2008
    Tyneside
    Stands for diesel "particulate" filter. Filters out particles of carbon.
    Apr 2008
    Liverpool
    Opps i did mean particulate
    asdasd
    ohh ok i havnt got a diesel then that problem cant affect me...Thankssssss
    WGAF#5
    how many miles the vehicle done? suspect particulate needs topping up between 70k and 90k dependant on if you shrt fill your car.
    if the fulid has been run dry or the particulate filter was blocked/clogged
    then there is a possibility the filter would need to be replaced as it sounds like the forced regeneration has not worked
    West Mids/Worcs
    70k on the clock, 55 plate
    topping up? how does that work then? what fluid?
    I'm getting confused! I thought the ceramic filter (DPF) was used instead of some fluid having to be added?
    WGAF#5
    the way most particulate filters work is like a honey trap
    every time you open/close your fuel filler flap a quantity of particulate fluid is added to the filter - this causes the carbons to stick to the interior of the cannister which are subsequently burnt off at high temps to reduce the amount of emissions your car produces
    hopefully you find this info helpful
    West Mids/Worcs
    I dont believe thats the way the Vauxhall DPF works
  1. Strange thing happened today?
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 16:54
  2. strange headlight thing tonight
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 04:15
  3. Strange thing happened this morning!!!
    By stuart813 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 20:29
  4. strange thing.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2009, 22:25
  5. A strange thing happened...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 18:40
